1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Epics Archiver Online Status Question
From: "Manoussakis, Adamandios via Tech-talk" <tech-talk at aps.anl.gov>
To: EPICS tech-talk <tech-talk at aps.anl.gov>
Date: Tue, 2 May 2023 20:10:36 +0000
Hi All,
Are there any PVs associated when you start up the Epic Archiver that you can read for status of the Archiver (Online, Running, Etc)?  If not does anyone have a simple solution to display in CSS GUI (LED or Text Box) that the archiver is in fact running, one thought was an ASUB record with some C written to check if the web interface of the archiver was reachable.
Adam
Re: Epics Archiver Online Status Question Tynan Ford via Tech-talk
RE: Epics Archiver Online Status Question [SEC=OFFICIAL] STARRITT, Andrew via Tech-talk
Prev: Re: Sequencer configuration file Andrew Johnson via Tech-talk
Next: Does anyone have documented PV Access run time ENV variables? Kim, Kuktae via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: Re: External: Questions about Function: epicsEventWaitWithTimeout (id, timeout) Niko Kivel via Tech-talk
Next: Re: Epics Archiver Online Status Question Tynan Ford via Tech-talk
ANJ, 04 May 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
