Hi Adam,
I don't know of a status PV associated with the archiver myself. We implemented a PV with a subroutine like you suggested. It queries an archiver appliance HTTP endpoint and determines if the archiver is up and running based on that.
For instance, you could check that mgmt/bpl/startupState, engine/bpl/startupState, etc. return "STARTUP_COMPLETE". Or query an endpoint like mgmt/bpl/getApplianceInfo and ensure it returns a valid response.
Best Tynan
On Tue, May 2, 2023 at 1:11 PM Manoussakis, Adamandios via Tech-talk < [email protected]> wrote:
Hi All,
Are there any PVs associated when you start up the Epic Archiver that you can read for status of the Archiver (Online, Running, Etc)? If not does anyone have a simple solution to display in CSS GUI (LED or Text Box) that the archiver is
in fact running, one thought was an ASUB record with some C written to check if the web interface of the archiver was reachable.
Adam
- Re: Epics Archiver Online Status Question Manoussakis, Adamandios via Tech-talk
- Epics Archiver Online Status Question Manoussakis, Adamandios via Tech-talk
Re: Does anyone have documented PV Access run time ENV variables? Michael Davidsaver via Tech-talk
Re: EPICS support for the Omega Platinum Series PID Controllers Michael Davidsaver via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
