1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Freeing allocated buffers in areaDetector HDF5 Plugin
To: "[email protected]" <[email protected]>, "Marco A. Barra Montevechi Filho" <[email protected]>
Date: Thu, 4 May 2023 00:43:01 +0000
Hi Marco,
"capture" mode is rarely needed.  When you write 1 to Capture it saves all frames into a buffer.  When you press the Save button (WriteFile PV) the frames are written to disk and what is complete they returned to the AD driver's free pool.
If you want to return that memory to the OS then you need to write 1 to the EmptyFreeList PV, which is shown in the Buffers section of the driver screen.  That Buffer section also shows the total number of buffers (NDArrays) allocated and the total memory allocations.  When you press that Empty button the allocated memory (PoolUsedMem PV) will drop to a small number.
Note that "top"may still show a large amount of memory allocated to the detector IOC.  That is because calling free() in Linux does not necessarily return the memory to the operating system.  Here is an explanation:
"capture" mode was created when the plugin queue size was fixed at iocInit.  Now that it can be changed at run-time there is very little need for "capture" mode.  Instead, most people use "stream" mode and make the queue size large enough that frames are not dropped.  "stream" mode writes the file at the same time that it is buffering frames, so it is generally faster and requires less memory than "capture" mode.  Do you have a special requirement that calls for "capture" mode?
> Consequently, when allocated buffer is bigger than available memory, application freezes my machine.
When you start your driver you can specify on the iocsh command line the maximum amount of memory it is allowed to use.   If you set that to a value less than your system RAM then it will generate an error but won't freeze your machine.
From: Tech-talk <[email protected]> on behalf of Marco A. Barra Montevechi Filho via Tech-talk <[email protected]>
Sent: Wednesday, May 3, 2023 6:41 PM
To: [email protected] <[email protected]>
Subject: Freeing allocated buffers in areaDetector HDF5 Plugin
Hi, all!
Im doing some proof of concepts with areaDetector cloned directly from master (commit 78fae55898b9028e756eb080367cd6aad8913b54) and the plugins together with EPICS_BASE 7.
When using the HDF5 plugin and saving with the capture mode, documentation (https://areadetector.github.io/master/ADCore/NDPluginFile.html?highlight=allocate) tells me a buffer will be allocated in memory before saving occurs. Consequently, when allocated buffer is bigger than available memory, application freezes my machine.
The thing is: after the saving occurs, the buffer doesnt seem to be de-allocated. I say that because htop shows memory usage growing continuously when acquire is happening with capture mode on, but memory usage does not decrease once saving is done. I tried using the <PREFIX>FlushNow PV but i only get this error:
epics> dbpf 13SIM2:HDF1:FlushNow 1
DBF_STRING:         "Flush"
epics> 2023/05/03 20:35:02.845 NDFileHDF5:writeInt32: ERROR status=3, function=168, value=1 old=0
2023/05/03 20:35:02.845 13SIM2:HDF1:FlushNow devBusyAsyn::processCallbackOutput process error
epics>
epics>
epics>
DBF_STRING:         "Flush"
epics> 2023/05/03 20:35:34.577 NDFileHDF5:writeInt32: ERROR status=3, function=168, value=1 old=0
2023/05/03 20:35:34.577 13SIM2:HDF1:FlushNow devBusyAsyn::processCallbackOutput process error
Is this the correct usage of the PV? I also tried using <PREFIX>NumFramesFlush, but got no result.
Is there any recommended way i can de-allocate this buffer whenever i want? Until now, i need to restart the application every time i want my memory back.
Thanks in advance for any help,
Marco
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Freeing allocated buffers in areaDetector HDF5 Plugin Marco A. Barra Montevechi Filho via Tech-talk
Prev: Freeing allocated buffers in areaDetector HDF5 Plugin Marco A. Barra Montevechi Filho via Tech-talk
Next: Re: Does anyone have documented PV Access run time ENV variables? Dmitry Yu. Bolkhovityanov via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Next: Re: Freeing allocated buffers in areaDetector HDF5 Plugin Marco A. Barra Montevechi Filho via Tech-talk
