1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Does anyone have documented PV Access run time ENV variables?
From: "Dmitry Yu. Bolkhovityanov via Tech-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>
Date: Thu, 4 May 2023 10:35:56 +0700 (+07)
Michael,
On Wed, 3 May 2023, Michael Davidsaver via Tech-talk wrote:
https://github.com/mdavidsaver/pvxs/blob/master/documentation/netconfig.rst
Thanks for a concise description of possible addressing methods!
I have a question related to addressing: the "pvAccess Protocol Specification" -- e.g. https://epics-controls.org/wp-content/uploads/2018/10/pvAccess-Protocol-Specification.pdf -- contains the following statement:
	A  client  API  MAY  also  allow  a  user-specified  server
	address;  in this case, the searching process would be bypassed
	and the specified server address data used directly.
The question is: does PVXS allow specifying a server address on a per-PV basis, e.g. "(SERVER_ADDRESS_SPEC)PV_NAME"? Or does the "user-specified server address" in the statement above mean "address specified via EPICS_PVA_ADDR_LIST" only?
Re: Does anyone have documented PV Access run time ENV variables? Michael Davidsaver via Tech-talk
Does anyone have documented PV Access run time ENV variables? Kim, Kuktae via Tech-talk
Re: Does anyone have documented PV Access run time ENV variables? Timo Korhonen via Tech-talk
Re: Does anyone have documented PV Access run time ENV variables? Andrew Johnson via Tech-talk
Re: Does anyone have documented PV Access run time ENV variables? Kim, Kuktae via Tech-talk
Prev: Re: Freeing allocated buffers in areaDetector HDF5 Plugin Mark Rivers via Tech-talk
Next: Re: Standard/clean way to copy NORD from one waveform to another (and aSub limitations) Jure Varlec via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Does anyone have documented PV Access run time ENV variables? Kim, Kuktae via Tech-talk
Next: Re: Does anyone have documented PV Access run time ENV variables? Michael Davidsaver via Tech-talk
