1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Does anyone have documented PV Access run time ENV variables?
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Dmitry Yu. Bolkhovityanov" <[email protected]>
Date: Fri, 5 May 2023 07:40:01 -0700
On 5/3/23 20:35, Dmitry Yu. Bolkhovityanov wrote:
Michael,
On Wed, 3 May 2023, Michael Davidsaver via Tech-talk wrote:
https://github.com/mdavidsaver/pvxs/blob/master/documentation/netconfig.rst
Thanks for a concise description of possible addressing methods!
I have a question related to addressing: the "pvAccess Protocol Specification" -- e.g. https://epics-controls.org/wp-content/uploads/2018/10/pvAccess-Protocol-Specification.pdf -- contains the following statement:
     A  client  API  MAY  also  allow  a  user-specified  server
     address;  in this case, the searching process would be bypassed
     and the specified server address data used directly.
The question is: does PVXS allow specifying a server address on a per-PV basis, e.g. "(SERVER_ADDRESS_SPEC)PV_NAME"?  Or does the "user-specified server address" in the statement above mean "address specified via EPICS_PVA_ADDR_LIST" only?
This has been possible since PVXS 0.2.0, although I notice that it isn't yet mentioned in the documentation.
The client *Builder objects have a server() method which takes a hostname/IP address.
https://github.com/mdavidsaver/pvxs/blob/dd2f076b4aa6dc63fb91980eda711eabee910696/src/pvxs/client.h#L685
An example usage in the pvxlist executable.
https://github.com/mdavidsaver/pvxs/blob/dd2f076b4aa6dc63fb91980eda711eabee910696/tools/list.cpp#L162
Also, it may not be relevant for you, but do be aware that some servers based on pvAccessCPP have a bug
whereby PV names must be searched for by some client before any client can create a channel.
In general, I'm not sure I would recommend bypassing the search phase as a regular operation.  Depending
on your use case you might prefer search over TCP (set $EPICS_PVA_NAME_SERVERS).
Does anyone have documented PV Access run time ENV variables? Kim, Kuktae via Tech-talk
Re: Does anyone have documented PV Access run time ENV variables? Timo Korhonen via Tech-talk
Re: Does anyone have documented PV Access run time ENV variables? Andrew Johnson via Tech-talk
Re: Does anyone have documented PV Access run time ENV variables? Kim, Kuktae via Tech-talk
Re: Does anyone have documented PV Access run time ENV variables? Michael Davidsaver via Tech-talk
Re: Does anyone have documented PV Access run time ENV variables? Dmitry Yu. Bolkhovityanov via Tech-talk
Prev: RE: SNL graph generator Žiga Oven via Tech-talk
Next: Re: Epics Archiver Online Status Question Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Does anyone have documented PV Access run time ENV variables? Dmitry Yu. Bolkhovityanov via Tech-talk
Next: Bug in ADPICam driver found. Jörn Dreyer via Tech-talk
