1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Does anyone have documented PV Access run time ENV variables?
From: "Kim, Kuktae via Tech-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>
Date: Wed, 3 May 2023 19:38:03 +0000
Hello Michael,
That sounds great! Thank you for suggesting that I get involved in improving the PVXS document. I am happy to do so.
Best regards,
Kuktae
Sent: Wednesday, May 3, 2023 10:47 AM
To: Kim, Kuktae <[email protected]>
Cc: Andrew Johnson <[email protected]>; Timo Korhonen <[email protected]>; tech-talk <[email protected]>
On 5/3/23 08:32, Kim, Kuktae via Tech-talk wrote:
> Hi Timo, Steven, and Andrew,
> I wanted to thank you for your prompt replies. Your responses have provided me with all the information that I needed, and I appreciate your help.
> Thank you very much.
Hi Kuktae,
I hope that you will find time to update some of the documentation you
looked at so that it can become "sufficient" and "more comprehensive".
Like OSS code, our documentation is only as good as we make it!
https://github.com/mdavidsaver/pvxs/blob/master/documentation/netconfig.rst
Does anyone have documented PV Access run time ENV variables? Kim, Kuktae via Tech-talk
Re: Does anyone have documented PV Access run time ENV variables? Timo Korhonen via Tech-talk
Re: Does anyone have documented PV Access run time ENV variables? Andrew Johnson via Tech-talk
Re: Does anyone have documented PV Access run time ENV variables? Kim, Kuktae via Tech-talk
Re: Does anyone have documented PV Access run time ENV variables? Michael Davidsaver via Tech-talk
Prev: Re: Epics Archiver Online Status Question Manoussakis, Adamandios via Tech-talk
Next: Standard/clean way to copy NORD from one waveform to another (and aSub limitations) Érico Nogueira Rolim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Does anyone have documented PV Access run time ENV variables? Michael Davidsaver via Tech-talk
Next: Re: Does anyone have documented PV Access run time ENV variables? Dmitry Yu. Bolkhovityanov via Tech-talk
