1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Power strip with ehthernet interfacet to allow remote control -- (1-2 ports)
From: "Luchini, Kristi L. via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 4 May 2023 16:49:57 +0000
Hello,
We use ethernet power strips from APC that allow remote control (on/off/reboot) of each port on the power strip individually.  The standard number of ports is 8 but we also use power strips with more ports. However, I  only need one port that will be installed in up to 35 chassis (installed in the tunnel) that will allow the power cycle the hardware plugged into this port, if necessary.  I really don’t want to purchase a 8 port power strip when I only need 1 port.  If another lab uses such a device, I’d also like to download the EPICS driver, or asyn protocol file to talk to the device. I realize that many of these devices come with a web interfaces, but want to integrate this into the EPICS control system. Also  web interfaces are generally not permitted on our production systems.
Any recommendations would be appreciated.
-Kristi
Re: Power strip with ehthernet interfacet to allow remote control -- (1-2 ports) Han Lee via Tech-talk
Prev: Re: Freeing allocated buffers in areaDetector HDF5 Plugin Marco A. Barra Montevechi Filho via Tech-talk
Next: Re: Power strip with ehthernet interfacet to allow remote control -- (1-2 ports) Han Lee via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: Re: Support module for PV pre-defined values Pueyos, Armando (DLSLtd, RAL, LSCI) via Tech-talk
ANJ, 04 May 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
