1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Why does libca.so depend on libreadline.so?
From: "Dmitry Yu. Bolkhovityanov via Tech-talk" <[email protected]>
To: Han Lee <[email protected]>
Cc: [email protected]
Date: Wed, 10 May 2023 15:06:03 +0700 (+07)
Hi!
On Mon, 8 May 2023, Han Lee wrote:
Hi Dmitry,
I think the head file (especially comments in the file) may be what you are
interested in to get your understanding.
https://github.com/epics-base/epics-base/blob/7.0/modules/libcom/src/osi/epicsReadline.h
Well, this documents the epicsReadline library, but doesn't explain why it is required for libCom.
From my naive understanding, it is required for an iocsh functionality.
Thanks!  The "iocsh" is the keyword.
When googling for "libca.so readline site:anl.gov" I finally encountered a message "Re: Problem installing PyEpics" (https://epics.anl.gov/tech-talk/2017/msg00206.php) from Andrew Johnson, 30 Jan 2017, with a short phrase
	    The core of iocsh is a part of libCom.
Yes, this explains it all.
Albeit the design looks extremely surprising -- as if some IP implementation included an integrated ksh...
However, a brief investigation had found this had changed in the 7.0.x between 7.0.2 and 7.0.7: in 7.0.2 the libca.so.4.13.3 does have a dependency on libreadline, while 7.0.7's libca.so.4.14.2 does NOT.
So, if 7.0.x was refactored to get rid of this dependency, then this change can probably be back-ported to 3.15.x. A quick inspection of https://epics.anl.gov/base/R7-0/7-docs/RELEASE_NOTES.html doesn't show any traces of this change; probably a "diff -Naur" between sources is required. I'm not sure my skills are sufficient for this back-porting, but I'll try.
With best regards,
Dmitry
On Mon, May 8, 2023 at 9:46?PM Dmitry Yu. Bolkhovityanov via Tech-talk <
[email protected]> wrote:
Michael,
On Sun, 7 May 2023, Michael Davidsaver wrote:
On 5/6/23 23:12, Dmitry Yu. Bolkhovityanov via Tech-talk wrote:
 P.S. Yes, I'm aware of a "COMMANDLINE_LIBRARY=EPICS" flag (which took
some
 time to figure out :D), but the question remains -- why any commandline
 editing is needed for network communication libraries at all?
This is a side-effect of the convention we use to support both dynamic
and
static linking
with one configuration.  Since static libraries do not carry dependency
information, when
linking statically it is necessary to give a complete list of all
dependent
libraries
when linking any executable.  This includes libreadline when libCom
depends
on it.
One simple way to avoid this over-linking in the dynamic case by passing
"-Wl,--as-needed"
when linking.
(assumes GCC or clang on an ELF target)
Thanks for this -- I didn't know of this linker option!
However, I still don't understand: why libCom depends on libreadline (or
any commandline-editing library)?
With best regards,
Dmitry
Re: Why does libca.so depend on libreadline.so? Andrew Johnson via Tech-talk
Why does libca.so depend on libreadline.so? Dmitry Yu. Bolkhovityanov via Tech-talk
Re: Why does libca.so depend on libreadline.so? Michael Davidsaver via Tech-talk
Re: Why does libca.so depend on libreadline.so? Dmitry Yu. Bolkhovityanov via Tech-talk
Re: Why does libca.so depend on libreadline.so? Han Lee via Tech-talk
Prev: Issue on PDB-event / base 7.0.7 ? Gabriel Fedel via Tech-talk
Next: Re: PvaPy pvaccess Simon Rose via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Why does libca.so depend on libreadline.so? Han Lee via Tech-talk
Next: Re: Why does libca.so depend on libreadline.so? Andrew Johnson via Tech-talk
