1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: PvaPy pvaccess
To: S Banerian <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 10 May 2023 08:54:41 +0000
Hello S Banerian -
It looks to me like you are simply missing an import in python. Since you haven't shared the whole of your python code I can't tell, but you might be missing a
from pvaccess import CA
at the top of your script. Note that according to your linked documentation there is such an object:
  >>> import pvaccess
  >>> dir (pvaccess)
  ['BOOLEAN', 'BYTE', 'CA', 'Channel', 'DOUBLE', 'FLOAT', 'FieldNotFound',
  'INT', 'InvalidArgument', 'InvalidDataType', 'InvalidRequest', 'LONG',
  'NtTable', 'NtType', 'PVA', 'ProviderType', 'PvAlarm', 'PvBoolean', 'PvByte',
  'PvDouble', 'PvFloat', 'PvInt', 'PvLong', 'PvObject', 'PvScalar',
  'PvScalarArray', 'PvShort', 'PvString', 'PvTimeStamp', 'PvType', 'PvUByte',
  'PvUInt', 'PvULong', 'PvUShort', 'PvUnion', 'PvaException', 'RpcClient',
  'RpcServer', 'SHORT', 'STRING', 'UBYTE', 'UINT', 'ULONG', 'USHORT', '__doc__',
  '__file__', '__name__', '__package__']
See the third entry in the output of dir(pvaccess)
Cheers,
Simon
On 2023-05-10, 10:47, "Tech-talk on behalf of S Banerian via Tech-talk" <[email protected] <mailto:[email protected]> on behalf of [email protected] <mailto:[email protected]>> wrote:
I've set to work on upgrading some of our local EPICS infrastructure, and have (finally) installed Epics 7 on a couple of machines.
As part of that, we are trying out pvaccess PvaPy as an update to the pyepics that is currently used.
On a test system, i've been following the documentation [1,2] for PvaPy to monitor some pv's we track.
alas, we do not get the desired behaviour for monitoring CA PVs.
pvaChannel = Channel('enum01')
pvaChanne.isConnected()
pvaChannel.subscribe('echo', lambda x: print(f'{x}'))
pvaChannel.startMonitor()
(no errors encountered)
but when non-default is tried:
ourPVchannel = pvaccess.Channel('int01',CA)
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
NameError: name 'CA' is not defined
pvaccess.Channel('int01',providerType=CA)
suggestions as to what I can try next?
[1] https://github.com/epics-base/pvaPy <https://github.com/epics-base/pvaPy>
[2] https://epics.anl.gov/extensions/pvaPy/production/pvaccess.html#channel <https://epics.anl.gov/extensions/pvaPy/production/pvaccess.html#channel>
s banerian
UW Clinical Cyclotron
PvaPy pvaccess S Banerian via Tech-talk
Prev: Re: Why does libca.so depend on libreadline.so? Dmitry Yu. Bolkhovityanov via Tech-talk
Next: Re: [EXTERNAL] PvaPy pvaccess Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: PvaPy pvaccess S Banerian via Tech-talk
