1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: RE: When I use an IOC in a container, streamDevice occasionally reports that protocol has been aborted, which causes the records in the IOC to become inaccessible from the host computer.
From: "Wang, Andrew via Tech-talk" <[email protected]>
To: Mark Rivers <[email protected]>, Zimoch Dirk <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 12 May 2023 23:27:42 +0000
Hi Mark and Dirk,
Thank you for your responses. I will do my best to identify if it is a container or EPICS issue by separating out the IOC from the container as soon as possible. It won’t be until later next week unfortunately.
Sent: Friday, May 12, 2023 3:29 PM
To: Zimoch Dirk <[email protected]>; Wang, Andrew <[email protected]>
Timeouts in the protocol should be recoverable.  From what I understand once this happens all CA access to the IOC is lost.  If so, this is a more serious issue.
From: Tech-talk <[email protected]> On Behalf Of Zimoch Dirk via Tech-talk
Sent: Friday, May 12, 2023 2:16 PM
To: Wang, Andrew <[email protected]>
Subject: Re: When I use an IOC in a container, streamDevice occasionally reports that protocol has been aborted, which causes the records in the IOC to become inaccessible from the host computer.
Hi Andy,
I suspect your container stalls from time to time, causing timeouts in the protocol.
I do not think that containers have been designed with real-time performance in mind. Thus I am not really surprised that it does not behave like a pure host. Maybe you can tune how the host schedules the containers? Or reduce the number of containers per host? It may simply be overburdened. Do you have any figures on the system load?
Dirk
Am 12.05.2023 um 20:06 schrieb Wang, Andrew via Tech-talk <[email protected]>:
Hi all,
I have created multiple IOCs for the project in which I am involved. They are all running in their own Docker container in a host computer running Ubuntu 20.04. In each Docker container, the following EPICs and support module versions are used.
  1. EPICS: 7.0.4
  2. StreamDevice: 2.8.15
  3. Asyn: 4.41
In one of the IOCs, I have a SSEQ record that is used to push a scalar value to multiple records that set four parameters for the target instrument. There is an instance where streamDevice is unable to push the value to the second parameter, causing the protocol to abort. Then, a few minutes later, my colleagues and I have observed that no records from the IOC in question can be accessed through Channel Access. This is the error message that we receive.
Read operation timed out: some PV data was not read.
<RECORD_NAME> 0
CA.Client.Exception……………………………………………………..
Warning: “Virtual circuit disconnect”
Context: “op=0, channel=<RECORD_NAME>, type=DBR_TIME_DOUBLE, count=1, ctx=”<IP ADDRESS:PORT>”
Source File: ../getCopy.cpp line 91
Current Time: <TIME>
This also meant that I was unable to check the STAT field to see what the cause of the abortion was.
Thank you and I look forward to hearing back from everyone.
Andy
Purple ribbon awareness
Re: When I use an IOC in a container, streamDevice occasionally reports that protocol has been aborted, which causes the records in the IOC to become inaccessible from the host computer. Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
When I use an IOC in a container, streamDevice occasionally reports that protocol has been aborted, which causes the records in the IOC to become inaccessible from the host computer. Wang, Andrew via Tech-talk
Re: When I use an IOC in a container, streamDevice occasionally reports that protocol has been aborted, which causes the records in the IOC to become inaccessible from the host computer. Zimoch Dirk via Tech-talk
RE: When I use an IOC in a container, streamDevice occasionally reports that protocol has been aborted, which causes the records in the IOC to become inaccessible from the host computer. Mark Rivers via Tech-talk
Prev: RE: When I use an IOC in a container, streamDevice occasionally reports that protocol has been aborted, which causes the records in the IOC to become inaccessible from the host computer. Mark Rivers via Tech-talk
Next: Re: Why does libca.so depend on libreadline.so? Dmitry Yu. Bolkhovityanov via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: Re: When I use an IOC in a container, streamDevice occasionally reports that protocol has been aborted, which causes the records in the IOC to become inaccessible from the host computer. Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
