Hi Michael,
On Thu, 11 May 2023, Michael Davidsaver wrote:
On 5/11/23 01:38, Dmitry Yu. Bolkhovityanov via Tech-talk wrote:
The next step will be to find which git commit bringed this change.
https://github.com/epics-base/epics-base/pull/254
May I suggest a small addition to your patch? It modifies behaviour for
old, non-__has_include()-enabled compilers, thus eliminating a regression
(and solving Mark Rivers' problem mentioned in
https://epics.anl.gov/core-talk/2022/msg00385.php). The idea is to fall
back to old readline detection method instead of defaulting to =EPICS
(the whole file is attached):
% diff -ub ./base-7.0.7/configure/toolchain.c{.orig,}
--- ./base-7.0.7/configure/toolchain.c.orig 2022-09-08 01:50:35.000000000 +0700
+++ ./base-7.0.7/configure/toolchain.c 2023-05-13 13:12:20.967486783 +0700
@@ -45,5 +45,7 @@
COMMANDLINE_LIBRARY ?= EPICS
# endif
#else
-COMMANDLINE_LIBRARY ?= EPICS
+COMMANDLINE_LIBRARY ?= $(strip $(if $(wildcard \\
+ $(firstword $(READLINE_DIR) $(GNU_DIR))/include/readline/readline.h), \\
+ READLINE, EPICS))
#endif
The detection snippet was copied from
configure/os/CONFIG_SITE.Common.linux-arm as it tries 2 dirs instead of 1
as most other places do.
I've tested it on CentOS-7.3 (gcc version 4.8.5 20150623) and now
libCom.so.3.22.0 does get a libreadline.so dependency.
(However, as I don't have access to neither vxWorks/RTEMS nor MinGW etc.,
can't check behaviour on such systems.)
The only oddity which puzzled me is integration of commandline editing
into libCom -- that looks completely out of place.
Hardly the only historical oddity in a ~30 year old code base.
(at least we don't link in libX11 ...)
As funny as linking in libX11 looks, there could be a reasonable scenario
for libXt: that can be used as application's main loop, taking care of
file descriptors and timeouts, similarly to fdManager. :)
With best regards,
Dmitry #ifdef _COMMENT_
/* Extract compiler pre-defined macros as Make variables
* Expanded as $(INSTALL_CFG)/TOOLCHAIN.$(EPICS_HOST_ARCH).$(T_A)
* Must be careful not to #include any C definitions
* into what is really a Makefile snippet
* cf. https://sourceforge.net/p/predef/wiki/Home/
/* GCC preprocessor drops C comments from output.
* MSVC preprocessor emits C comments in output
#endif
#if defined(__GNUC__) && !defined(__clang__)
GCC_MAJOR = __GNUC__
GCC_MINOR = __GNUC_MINOR__
GCC_PATCH = __GNUC_PATCHLEVEL__
#elif defined(__clang__)
CLANG_MAJOR = __clang_major__
CLANG_MINOR = __clang_minor__
CLANG_PATCH = __clang_patchlevel__
#elif defined(_MSC_VER)
MSVC_VER = _MSC_VER
#endif
#ifdef __rtems__
#include <rtems/score/cpuopts.h>
# if __RTEMS_MAJOR__>=5
OS_API = posix
# else
OS_API = score
# endif
#endif
#ifdef __has_include
# if defined(__rtems__) && __RTEMS_MAJOR__<5 && __has_include(<libtecla.h>)
COMMANDLINE_LIBRARY ?= LIBTECLA
# elif __has_include(<readline/readline.h>)
COMMANDLINE_LIBRARY ?= READLINE
# else
# endif
#else
READLINE, EPICS))
#endif
- Re: Why does libca.so depend on libreadline.so? Michael Davidsaver via Tech-talk
- Why does libca.so depend on libreadline.so? Dmitry Yu. Bolkhovityanov via Tech-talk
- Re: Why does libca.so depend on libreadline.so? Dmitry Yu. Bolkhovityanov via Tech-talk
- Re: Why does libca.so depend on libreadline.so? Han Lee via Tech-talk
- Re: Why does libca.so depend on libreadline.so? Andrew Johnson via Tech-talk
RE: When I use an IOC in a container, streamDevice occasionally reports that protocol has been aborted, which causes the records in the IOC to become inaccessible from the host computer. Wang, Andrew via Tech-talk
<2023>
2025
2026
Re: Why does libca.so depend on libreadline.so? Ralph Lange via Tech-talk
<2023>
2025
2026
