1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: _registerRecordDeviceDriver warning
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "David A. Slimmer" <[email protected]>
Date: Mon, 15 May 2023 11:16:23 -0700
On 5/15/23 10:37, David A. Slimmer via Tech-talk wrote:
I’m trying to implement device support under base-7.0.5, and I’m getting the following warning when I compile:
Biascontroller_registerRecordDeviceDriver.cpp:382:62: warning: missing initializer for member 'iocshFuncDef::usage' [-Wmissing-field-initializers]
   382 |     {"Biascontroller_registerRecordDeviceDriver", 1, rrddArgs};
I looked at the Biascontroller_registerRecordDeviceDriver.cpp code, but it looks identical to the code generated for another project using device support built with an earlier version of EPICS base (R3.15 I think).
Any ideas where I might look to track this down?
Firstly, this warning can simply be ignored.  The "uninitialized" field will
be initialized to NULL in this context, which is the intent.
The warning comes from the addition of usage messages for IOC shell commands
in 7.0.4.
https://github.com/epics-base/epics-base/commit/ce4fb6085ffccd2ad0c29191d221c55341a485a6
There is no particular reason why the generated *_registerRecordDeviceDriver
commands don't have a usage message.  Although I can't immediately think of
what the wording would be.
As a note for _external_ modules wishing to provide a usage message, the macro
IOCSHFUNCDEF_HAS_USAGE can be tested to determine if iocshFuncDef::usage exists.
https://github.com/epics-base/epics-base/blob/cb97d662a74b8de6d7265a0863edbf88d0486f28/modules/database/src/template/top/exampleApp/src/_APPNAME_Hello.c#L20-L30
_registerRecordDeviceDriver warning David A. Slimmer via Tech-talk
Prev: _registerRecordDeviceDriver warning David A. Slimmer via Tech-talk
Next: ADEiger Monitor John Dobbins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
