1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: opc ua
From: "Blomley, Edmund \(IBPT\) via Tech-talk" <[email protected]>
To: "Sinclair, John" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 26 May 2023 04:18:51 +0000
Hey,
> Saying:
>      field( INP, "@opcua1 str:123,MyObject.MyVariable" )
> does not work but I could find nothing in the documentation that describes the syntax for this case.
I think you are missing quotation marks around the strings. For your case I would try:
field( INP, "@opcua1 str:123,\"MyObject\".\"MyVariable\"" )
In general I find it helpful to use a OPC UA client to connect to the OPC server and look up the proper names of the relevant channels.
For example this one: https://www.unified-automation.com/downloads/opc-ua-clients.html
Cheers
eddy
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: opc ua Jörn Dreyer via Tech-talk
Prev: opc ua Sinclair, John via Tech-talk
Next: Re: opc ua Jörn Dreyer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: opc ua Ralph Lange via Tech-talk
