1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: opc ua
From: "Sinclair, John via Tech-talk" <[email protected]>
To: tech-talk <[email protected]>
Date: Thu, 25 May 2023 20:30:35 +0000
I have a simple IOC talking to an opc/ua simulation server using the open open62541 library.
I do not know how to identify an opc variable which is a member of an object except for displaying its numeric index on the server.
The object name is MyObject, the variable is MyVariable.
Saying:
        field( INP, "@opcua1 num:123,2" )
works, because i determined the variable's index(2, in the above) on the server.
Saying:
      field( INP, "@opcua1 str:123,MyObject.MyVariable" )
does not work but I could find nothing in the documentation that describes the syntax for this case.
I also tried MyObject:MyVariable without success.
Does anyone know the correct syntax?
John Sinclair
Re: opc ua Ralph Lange via Tech-talk
Prev: Re: makefile question about HDEPENDS Andrew Johnson via Tech-talk
Next: Re: opc ua Blomley, Edmund (IBPT) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Next: Re: opc ua Ralph Lange via Tech-talk
