1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: makefile question about HDEPENDS
From: Andrew Johnson via Tech-talk <[email protected]>
To: timesir <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 26 May 2023 09:55:45 -0500
On 5/26/23 7:21 AM, timesir wrote:
Thanks for you reply.
I found than when I make a <top> area. When matched into epics-base/configure/RULES_BUILD, the "$(filter-out $(wildcard *$(DEP)), $(HDEPENDS_FILES)): | $(COMMON_INC)" statement  will be first matched instead of "all" or "install" target.  Could you explain it?
In the version of RULES_BUILD that we deliver with Base the all: target is defined before that line, so no I can't explain what you describe. Have you modified that or any of the other files at all? Did you create your top area using the makeBaseApp.pl script or some other way?
- Andrew
PS: Please continue to reply to the tech-talk list so others such as Simon can help you as well, I might not be able to respond to further emails myself for a while.
Andrew Johnson <[email protected]> 于2023年5月25日周四 23:25写道:
On 5/25/23 9:20 AM, Simon Rose via Tech-talk wrote:
Hi timesir –
This is how the build system generates the .d (dependency) files for each of the source files. See https://github.com/epics-base/epics-base/blob/7.0/configure/CONFIG_COMMON#L135 for the definition.
The HDEPENDS.c is the mechanism to generate these files; these are also in the same file, see https://github.com/epics-base/epics-base/blob/7.0/configure/CONFIG_COMMON#L378. For example, if HDEPENDS_METHOD = COMP then it uses the C/C++ compiler to generate these files; otherwise it uses mkmf (included in tools)
For certain architectures (e.g. gnu ones), these are used to compile source files, see here: https://github.com/epics-base/epics-base/blob/7.0/configure/RULES_BUILD#L117 – this will attempt to include all of these .d file and if (as above) HDEPENDS_METHOD = COMP then it will try to generate those .d files by running  $(HDEPENDS.c) (a.k.a. the actual compiler), which will generate both the dependency file and the resulting object file at the same time.
Actually we moved away from creating the .d files at the same time as compiling the .c/.cc/.cpp files in Base 3.15, now there we have separate build rules for the .d files — see lines 238-248 vs 257-267 of RULES_BUILD. Make works better if you have only one output file generated by each rule, and there are situations where the build avoids recreating the .d files unnecessarily.
- Andrew
From: Tech-talk <[email protected]> on behalf of timesir via Tech-talk <[email protected]>
Reply to: timesir <[email protected]>
Date: Thursday, 25 May 2023 at 16:00
Subject: makefile question about HDEPENDS
Dear community:
%$(DEP):%.c
        @$(RM) $@
        $(HDEPENDS.c) $<
How to understand these makefile statement from epics-base/configure/RULES_BUILD file? Especially what's the meaning of HDEPENDS?
Complexity is free, it's Simplicity that takes work.
makefile question about HDEPENDS timesir via Tech-talk
Re: makefile question about HDEPENDS Simon Rose via Tech-talk
Re: makefile question about HDEPENDS Andrew Johnson via Tech-talk
Prev: Re: Re:RE: no bin file Mark Rivers via Tech-talk
Next: Making mbbo record write string value instead of index Sobhani, Alex via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: makefile question about HDEPENDS Andrew Johnson via Tech-talk
Next: opc ua Sinclair, John via Tech-talk
