1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Making mbbo record write string value instead of index
From: "Sobhani, Alex via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 26 May 2023 15:01:50 +0000
I want multiplexor-like functionality with epics records, where the user can select from a number of PVs to display using a selector PV, and then an output PV displays whatever PV was selected.
My current implementation is this:
record(mbbo, "mot:select"){
      field(ZRST, "q8i:ai1 CP")
      field(ONST, "q8i:ai2 CP")
      field(FLNK, "mot:copy")
record(stringout, "mot:copy"){
      field(OMSL, "closed_loop")
      field(DOL, "mot:select")
      field(OUT, "mot:pos.INPA CA")
      field(FLNK, "mot:pos")
record(calc, "mot:pos"){
      field(CALC, "A")
The mbbo record allows the user to select his choice using a combobox widget in CSS, and then the value of the selected PV is displayed in the mot:pos record.
This works, but I am wondering if this can be done using two records instead of three. I attempted the following:
record(mbbo, "mot:select2"){
        field(OUT, "mot:pos2.INPA CA")
record(calc, "mot:pos2"){
      field(CALC, "A")
But this just ends up writing the index of the selection (0 or 1) to mot:pos2.INPA, instead of the pv link ("q8i:ai1 CP" or "q8i:ai2 CP"), even though "dbgf mot:select2.VAL" returns "q8i:ai2 CP".
This is not the behavior I would expect because the documentation says:
"If the OUT output link specifies a database link, channel access link, or constant, then the DTYP field must specify either one of the two soft device support modules-- Soft Channel or Raw Soft Channel. Soft Channel writes the value of VAL to the output link, without any conversion, while Raw Soft Channel writes the value from RVAL after it has undergone the above conversion."
And when I do "dbgf mot:select2.DTYP" it returns "Soft Channel".
So why does the VAL field get converted to an integer?
Alex
Prev: Re: makefile question about HDEPENDS Andrew Johnson via Tech-talk
Next: Re: [EXTERNAL] Re: opc ua Sinclair, John via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: Re: [EXTERNAL] Re: opc ua Sinclair, John via Tech-talk
Next: Issues with epics module and ISEG HAL service libraries Yann Mandza via Tech-talk
ANJ, 28 May 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
