1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Re: [EXTERNAL] Re: opc ua
From: "Sinclair, John via Tech-talk" <tech-talk at aps.anl.gov>
To: tech-talk <tech-talk at aps.anl.gov>
Date: Fri, 26 May 2023 15:58:51 +0000
I have previously installed the python opcua (actually opcua-asyncio) for the server simulation. The server creates the object MyObject with a member variable MyVariable.
The opcua-asyncio python client reads this as follows:
        # Get the variable node for read / write
        var = await client.nodes.root.get_child(
            ["0:Objects", f"{nsidx}:MyObject", f"{nsidx}:MyVariable"]
        value = await var.read_value()
As suggested below, I tried
        field( INP, "@opcua1 str:123,\"MyObject\".\"MyVariable\"" )
I also tried
        field( INP, "@opcua1 str:123,\"MyObject.MyVariable\"" )
        field( INP, "@opcua1 str:123,\'MyObject\'.\'MyVariable\'" )
        field( INP, "@opcua1 str:123,\'MyObject.MyVariable\'" )
In every case, I get the error message from the IOC:
Error reading from node: BadNodeIdUnknown
In the server code, I can print the namespace index and node id which, for the above is 123 and 2 respectively.
Doing
        field( INP, "@opcua1 num:123,2" )
does work and gets the correct value.
John
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Jörn Dreyer via Tech-talk <tech-talk at aps.anl.gov>
Sent: Friday, May 26, 2023 1:54 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: [EXTERNAL] Re: opc ua
Am Freitag, 26. Mai 2023, 06:18:51 CEST schrieb Blomley, Edmund (IBPT) via
Tech-talk:
> Hey,
> > Saying:
> >      field( INP, "@opcua1 str:123,MyObject.MyVariable" )
> > does not work but I could find nothing in the documentation that describes
> > the syntax for this case.
> I think you are missing quotation marks around the strings. For your case I
> would try:
> In general I find it helpful to use a OPC UA client to connect to the OPC
> server and look up the proper names of the relevant channels. For example
> this one: https://urldefense.us/v2/url?u=https-3A__www.unified-2Dautomation.com_downloads_opc-2Dua-2Dclients.html&d=DwIFaQ&c=v4IIwRuZAmwupIjowmMWUmLasxPEgYsgNI-O7C4ViYc&r=y1ySv2e6R1vXjM6-S-0q8nP52didqNXa2-iA6BX9G3w&m=jo1RgfpgortAIJVWuXWuI8DHNQ8N-IytVG--U3aloVKHHB650IhQAhzS0kLB_xzj&s=Apx5AxvkpcpVpVguN0iATlc-zoHyzlgDH5fRnexGdzk&e=
There is also a Python program called opcua-client that you can install via
pip.
Regards
Jörn
Re: opc ua Blomley, Edmund (IBPT) via Tech-talk
Re: opc ua Jörn Dreyer via Tech-talk
Prev: Making mbbo record write string value instead of index Sobhani, Alex via Tech-talk
Next: Issues with epics module and ISEG HAL service libraries Yann Mandza via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: Re: opc ua Jörn Dreyer via Tech-talk
Next: Making mbbo record write string value instead of index Sobhani, Alex via Tech-talk
ANJ, 28 May 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
