1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: More precise timing for record processing
To: "[email protected]" <[email protected]>, "Sobhani, Alex" <[email protected]>
Date: Tue, 30 May 2023 12:12:01 +0000
Hi Alex,
I think you could do it with a seq record something like this:
record(seq,"BL0:mytimer")
        field(DLY1,"2.7")
        field(DOL1,"1")
        field(LNK1,"BL0:mytrigger.PROC")
        field(FLNK,"BL0:mytimer")
I have not tested it.
From: Tech-talk <[email protected]> on behalf of Sobhani, Alex via Tech-talk <[email protected]>
Sent: Sunday, May 28, 2023 8:35 PM
To: [email protected] <[email protected]>
Subject: More precise timing for record processing
The SCAN field lets you choose from .1, .2, .5, 1, 2, 5, or 10 seconds. In cases where this is not enough, is there a simple way to make a record process at other intervals such as 2.7 seconds or 5.4 seconds, specified at runtime? I know you can add options for more periods of the SCAN field by editing dbd files, but you cannot change your mind at runtime.
I envision something like this:
record(timer, “BL0:mytimer”){
                field(PERI, 2.7)
                field(FLNK, “BL0:mytrigger”)
And then subfields to enable/disable it.
Does anything like this exist? I would imagine that something like this would be very generally useful.
Alex
More precise timing for record processing Sobhani, Alex via Tech-talk
Prev: Re: Problems when compiling areaDetector out of synapps, but using some synapps modules. Mark Rivers via Tech-talk
Next: Re: Maxnet cant open omsAsyn no such file or directory Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: More precise timing for record processing Sobhani, Alex via Tech-talk
Next: Re: More precise timing for record processing Arnold, Ned D. via Tech-talk
