On 6/8/23 06:53, Wang, Lin via Tech-talk wrote:
Dear all,
In PVXS, when iterating over the tree structure of pvxs::Value with the approach similar to top() method in the following link,
_https://github.com/mdavidsaver/pvxs/blob/master/src/datafmt.cpp_
is it possible to know if the current field is the last node of the parent struct with pvxs::impl::FieldDesc or pvxs::impl::FieldStorage?
For example, I am wondering how to check "message" field is the last node of struct "alarm_t" when iterating.
struct "alarm_t" {
int32_t severity = 2
int32_t status = 1
string message = "HIHI"
} alarm
The interface for iterating through the fields of a structure in brief is:
Value top(...); // some TypeCode::Structure
for(Value child : top.ichildren()) { ... }
Which is shorthand for something equivalent to:
Value::IChildren range(top.ichildren());
for(Value::IChildren::iterator cur(range.begin()), end(range.end()); cur!=end; ++cur) { Value child(*cur); ... }
cf. https://en.cppreference.com/w/cpp/language/range-for
One way to accomplish what you are asking with c++ iterators generally would be to track
both the "current" and "next" items.
for(Value::IChildren::iterator end(range.end()), next(range.begin()), cur(next!=end ? next++ : end);
cur!=end;
cur=next, next!=end ? ++next : end
) { if(next==end) printf("last!\n"); }
Also, this is the same pattern could be used to eg. allow safe removal of 'cur' while iterating
an std::list.
You may come across other variations on this pattern, some using a while loop
instead. This is ~equivalent functionally, and imo. ~equally ugly.
Value::IChildren::iterator end(range.end()), next(range.begin());
while(next!=end) {
Value::IChildren::iterator cur=next++;
- Is it possible to know if current field is the last node of parent struct in PVXS Wang, Lin via Tech-talk
RE: AreaDetector ADFFmpeg with FFmpeg 5.1 Daykin, Evan via Tech-talk
Re: Optional record alias Ralph Lange via Tech-talk
<2023>
2025
2026
PVA Gateway SegFault when pvcall (or eget) is used as a client Murray, Doug via Tech-talk
<2023>
2025
2026
