1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: add fields to an existing record
From: "Wolfman, Mark via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Cc: "Delgado, Uriel" <udelgado at anl.gov>
Date: Mon, 12 Jun 2023 16:25:53 +0000
Hi, tech-talkers.
Apologies in advance if parts of this don't make sense, I'm not that familiar with EPICS yet.
I'm hoping to add a new region-of-interest field [1] to the MCA records used in an existing IOC for our DXP fluorescence detector.
Similar to the other ROI fields, I'd like to have ``20bmxmap4b:mca1.R0BH``.
This will be a 'bi' field that doesn't do anything in the IOC, but is used by bluesky/ophyd during staging to determine whether the specific ROI is hinted in bluesky (hence BH for "bluesky hint") [2] and is included in the calculations for summing ROI's across elements. I've added extra records to an IOC before, and so I tried adding this as a record but EPICS complained because my record name included a '.' character.
One solution is to add a record like "20bmxmap4b:mca1_R0BH", but this makes the Ophyd part more complicated since the Ophyd MCA support expects the ROI to have a ``.Rn`` prefix and then tries to append the ``BH`` on the end[3]. Adding a record like ``mca1_R0BH`` means I have to re-write the MCA support in ophyd so I'd prefer to use the ``mca1.RnBH`` PVs if I can.
The full IOC is available on gitlab, though it's presently a work in progress.
Looking forward to hearing any ideas on how to make this work.
[1] https://epics-modules.github.io/mca/mcaRecord.html#Region-Of-Interest_Fields
[2] https://blueskyproject.io/ophyd/user_v1/reference/signals.html#kind
[3] https://github.com/bluesky/ophyd/blob/0802c77ec973b0ba9f8554d3bcf3a3001def7f66/ophyd/mca.py#L14
[4] https://git.aps.anl.gov/20BM/20bmdxp/-/tree/main/
Re: add fields to an existing record Mark Rivers via Tech-talk
Re: add fields to an existing record Wang Xiaoqiang via Tech-talk
Prev: Re: how to use the GUN-RC-300 in mrfioc2 Michael Davidsaver via Tech-talk
Next: Is HVCAENx527 Available Online for downloading? Weiwei Lu via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: Re: Optional record alias Ralph Lange via Tech-talk
Next: Re: add fields to an existing record Mark Rivers via Tech-talk
ANJ, 21 Jun 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
