1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: LabCA for MATLAB Installation error
From: Giovanni Franzini via Tech-talk <[email protected]>
To: <[email protected]>
Date: Wed, 14 Jun 2023 14:35:04 +0200
Hello,
I would like to have some help.
I am trying to install LabCA 3.8.1 with MATLAB 2023 in Windows10.
I have set my path in the RELEASE as
BASE_SUBDIR=/base/
EPICS_BASE=/c/msys64/home/Gio-Ufficio/base-7.0.7
MATLABDIR = /c/MATlink
(MATlink is a symbolic link to the installation directory: C:\Program Files\MATLAB\R2023a)
MATLIB_SUBDIR = win64/mingw64
(I also tried win64/microsoft)
When I run make (through MSYS2 MINGW64 ) I get the following error:
$ make
make: git: No such file or directory
make -C ./configure install
make[1]: Entering directory '/home/Gio-Ufficio/epics-labca-labca_3_8_1/configure'
make -C O.windows-x64-mingw -f ../Makefile TOP=../.. \
    T_A=windows-x64-mingw install
make[2]: Entering directory '/home/Gio-Ufficio/epics-labca-labca_3_8_1/configure/O.windows-x64-mingw'
perl -CSD /c/msys64/home/Gio-Ufficio/base-7.0.7/bin/windows-x64-mingw/convertRelease.pl checkRelease
echo MEXEXT=.mexw64 >>MATLAB_CONFIG_INCLUDE
make[2]: Leaving directory '/home/Gio-Ufficio/epics-labca-labca_3_8_1/configure/O.windows-x64-mingw'
make[1]: Leaving directory '/home/Gio-Ufficio/epics-labca-labca_3_8_1/configure'
make -C ./ezca install
make[1]: Entering directory '/home/Gio-Ufficio/epics-labca-labca_3_8_1/ezca'
make[2]: Entering directory '/home/Gio-Ufficio/epics-labca-labca_3_8_1/ezca/O.windows-x64-mingw'
make[2]: Nothing to be done for 'install'.
make[2]: Leaving directory '/home/Gio-Ufficio/epics-labca-labca_3_8_1/ezca/O.windows-x64-mingw'
make[1]: Leaving directory '/home/Gio-Ufficio/epics-labca-labca_3_8_1/ezca'
make -C ./glue install
make[1]: Entering directory '/home/Gio-Ufficio/epics-labca-labca_3_8_1/glue'
make[2]: Entering directory '/home/Gio-Ufficio/epics-labca-labca_3_8_1/glue/O.windows-x64-mingw'
g++          -DMATLAB_APP    -D_MINGW -D__USE_MINGW_ANSI_STDIO      -O3   -Wall      -m64    -DEPICS_BUILD_DLL -DEPICS_CALL_DLL    -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/WIN32 -I../../include    -I/c/msys64/home/Gio-Ufficio/base-7.0.7/include/compiler/gcc -I/c/msys64/home/Gio-Ufficio/base-7.0.7/include/os/WIN32 -I/c/msys64/home/Gio-Ufficio/base-7.0.7/include             -I../../ezca -I/c/MATlink/extern/include    -o ini.obj -c ../ini.cc
../ini.cc:22:13: error: conflicting declaration 'typedef int pid_t'
   22 | typedef int pid_t;
In file included from C:/msys64/mingw64/include/pthread.h:64,
                 from C:/msys64/mingw64/include/c++/13.1.0/x86_64-w64-mingw32/bits/gthr-default.h:35,
                 from C:/msys64/mingw64/include/c++/13.1.0/x86_64-w64-mingw32/bits/gthr.h:148,
                 from C:/msys64/mingw64/include/c++/13.1.0/ext/atomicity.h:35,
                 from C:/msys64/mingw64/include/c++/13.1.0/bits/ios_base.h:39,
                 from C:/msys64/mingw64/include/c++/13.1.0/ios:44,
                 from C:/msys64/mingw64/include/c++/13.1.0/ostream:40,
                 from C:/msys64/home/Gio-Ufficio/base-7.0.7/include/epicsTime.h:32,
                 from C:/msys64/home/Gio-Ufficio/base-7.0.7/include/db_access.h:21,
                 from C:/msys64/home/Gio-Ufficio/base-7.0.7/include/cadef.h:39,
                 from ../ini.cc:8:
C:/msys64/mingw64/include/sys/types.h:68:17: note: previous declaration as 'typedef _pid_t pid_t'
   68 | typedef _pid_t  pid_t;
../ini.cc:24:16: warning: 'int _getpid()' redeclared without dllimport attribute: previous dllimport ignored [-Wattributes]
   24 | extern "C" int _getpid();
make[2]: *** [/c/msys64/home/Gio-Ufficio/base-7.0.7/configure/RULES_BUILD:263: ini.obj] Error 1
make[2]: Leaving directory '/home/Gio-Ufficio/epics-labca-labca_3_8_1/glue/O.windows-x64-mingw'
make[1]: *** [/c/msys64/home/Gio-Ufficio/base-7.0.7/configure/RULES_ARCHS:58: install.windows-x64-mingw] Error 2
make[1]: Leaving directory '/home/Gio-Ufficio/epics-labca-labca_3_8_1/glue'
make: *** [/c/msys64/home/Gio-Ufficio/base-7.0.7/configure/RULES_DIRS:85: glue.install] Error 2
Any idea on what is the problem?
Thank you
Giovanni
Re: LabCA for MATLAB Installation error Straumann Till Sascha via Tech-talk
Prev: caget from win failed when xspress3 lynn via Tech-talk
Next: Re: C++ std problem Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: caget from win failed when xspress3 Yin, Zhijian via Tech-talk
Next: Re: LabCA for MATLAB Installation error Straumann Till Sascha via Tech-talk
