Hi Again,
0. install re2c package
1. rm -f GNUmakefile 2. echo "EPICS_BASE=your_epics_base" > configure/RELEASE.local
3. echo ASYN=$(INSTALL_LOCATION_ASYN)" >> configure/RELEASE.local echo "CALC=$(INSTALL_LOCATION_CALC)" >> configure/RELEASE.local echo "PCRE=" >> configure/RELEASE.local echo "CHECK_RELEASE = NO" > configure/CONFIG_SITE.local
sed -i -e "/^CHECK_RELEASE/d" configure/Makefile 4. make
HTH, Han
On Thu, Jun 15, 2023 at 12:09 PM Lang, Keenan C. via Tech-talk < [email protected]> wrote:
Hello Brandon,
EPICS modules are made aware about the location of other files they must include or link against through the use of the configure/RELEASE file. In StreamDevice, the configure/RELEASE file has the following line:
EPICS_BASE=/usr/local/epics/base-7.0.3
Thus, when you build, the module will try to find certain makefile rules, config files, headers, and libraries it needs in /usr/local/epics/base-7.0.3
When you are adding in a new module, you have to edit the configure/RELEASE file to match up the named macros with the locations where epics-base or the given modules are located on your system.
Keenan
Hello,
When I run make from ~/EPICS/support/stream/StreamDevice, I get these errors:
$ make
configure/CONFIG:18: /usr/local/epics/base-7.0.3/configure/CONFIG: No such file or directory
Makefile:33: /usr/local/epics/base-7.0.3/configure/RULES_TOP: No such file or directory
make: *** No rule to make target `/usr/local/epics/base-7.0.3/configure/RULES_TOP'. Stop.
Am I supposed to have an epics directory in /usr/local? I am unsure if this is an issue with setting paths correctly or an issue with my epics base install as I do not seem to see anything with the directory structure .../epics/base-7.0.3/...
Thank you,
Brandon
Jeong Han Lee, Dr.rer.nat. Staff Scientist and Engineer Cell: +1 510 384 3868
- Re: Issue installing StreamDevice on CentOS 7 Brandon Gunn via Tech-talk
- Issue installing StreamDevice on CentOS 7 Brandon Gunn via Tech-talk
- Re: Issue installing StreamDevice on CentOS 7 Lang, Keenan C. via Tech-talk
Re: cross-compiling v7.0.7 Pierrick M Hanlet via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
