1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: cross-compiling v7.0.7
From: Pierrick M Hanlet via Tech-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 15 Jun 2023 19:27:09 +0000
Hi Andrew,
In base/configure/ I modify:
- CONFIG_SITE to define CROSS_COMPILER_TARGET_ARCHS and
CROSS_COMPILER_HOST_ARCHS.
- CONFIG_COMMON to add USR_CXXFLAGS += -std=c++11
INSTALL_LOCATION remains commented out in CONFIG_SITE and I don't set it
anywhere else.
In base/configure/os/ I have additional files (most are unmodified):
CONFIG.Common.target-arch
CONFIG.linux-x86_64.target-arch
CONFIG_SITE.Common.target-arch
CONFIG_SITE.linux-x86_64.target-arch
where target-arch matches one in the list from CROSS_COMPILER_TARGET_ARCHS.
Of these, I modify CONFIG_SITE.Common.target-arch to point to the
cross-compiled
libraries, etc.
Yes, I have the EPICS_BASE set as an environment variable.  This allows
me to test my
build in my own area before pushing to a production build in our CI/CD
pipeline.
I don't use any command line flags with make apart from -s most of the
time, though
not at the moment until this is sorted.
Cheers,
Pierrick
On 6/15/23 14:05, Andrew Johnson wrote:
> Hi,
> There is something unexpected in your environment then because the
> file should be created properly — it is when everyone else runs
> 'make', and I'd like to work out what's different in your case; you
> shouldn't have to resort to creating it manually, or to replacing the
> RULES_MODULES file.
> Do you happen to have an environment variable 'EPICS_BASE' set? Are
> you providing any additional command-line parameters when you run
> make? Do you have any files or a 'configure' directory in the parent
> directory of where Base is installed? Do you set INSTALL_LOCATION in
> any configure files?
> - Andrew
> On 6/15/23 1:56 PM, Pierrick M Hanlet via Tech-talk wrote:
>> Greetings Andrew,
>> Oddly, even "make clean" creates the new file, so it's a bit of a
>> nuisance; I have to have one
>> terminal to run make and another one to update (copy a working version
>> of the RELEASE.linux-x86_64.local
>> file) after the build has started.
>> Interestingly, the v7.0.5 also has a RELEASE.linux-x86_64.local with
>> "EPICS_BASE = ", but
>> that did not adversely affect the build.
>> Note that we have no special build locations.
>> I'm running a test now, and it appears that if I use the v7.0.5
>> ./configure/RULES_MODULES,
>> everything works as before.
>> Cheers,
>> Pierrick
>> On 6/15/23 10:49, Andrew Johnson via Tech-talk wrote:
>>> Hi Pierrick,
>>> On 6/15/23 6:07 AM, Pierrick M Hanlet via Tech-talk wrote:
>>>> Something broke, or I missed new instructions in building the modules in
>>>> v7.0.7 for cross-compiled platforms.
>>>> I'm building for several platforms.  The host build is fine, but when
>>>> the cross-compiled platforms start building
>>>> a new RELEASE.linux-x86_64.local is created with "EPICS_BASE = ", i.e.
>>>> empty.  I did not experience this with
>>>> v7.0.5.
>>> Hopefully the fix should be to just delete that file and run 'make'
>>> again in that directory, but if you have a more complex local build
>>> process (e.g. if you're building on multiple host arch's) that might
>>> need some modifications. How were you doing the cross-builds?
>>> Getting the build rules right for generating the
>>> modules/RELEASE.<host>.local file was tricky, and there were some
>>> changes made to them between 7.0.5 and 7.0.7:
>>>> $ git log R7.0.5.. -- configure/RULES_MODULES
>>>> commit 098ee6c063c25c3b4483d7d5a0b6c8c6d8d17769
>>>> Author: Andrew Johnson<[email protected]>
>>>> Date:   Sat Sep 3 10:59:26 2022 -0500
>>>>      Oops: Fix to RULES_MODULES
>>>> commit efc7cbaf7f93c1bc58f98b30b9d20a27bc0a7f91
>>>> Date:   Fri Sep 2 14:10:27 2022 -0500
>>>>      Build system fixes related to INSTALL_LOCATION
>>>>      * The build can't descend into external submodules when there is no
>>>>      configure/RULES_TOP file present in $(INSTALL_LOCATION).
>>>>      * Recreate modules/RELEASE.<host>.local if configure/CONFIG_SITE or
>>>>      configure/CONFIG_SITE.local have changed.
>>>>      * Move the distclean of modules/RELEASE.<host>.local to RULES_TOP
>>>>      * Several comment and white-space changes
>>>> commit 191ff137f17eecde9e836f0f9aeaec5eecb73b24
>>>> Date:   Wed Nov 24 21:58:32 2021 -0600
>>>>      configure: Use GNU Make's abspath instead of fullPathname.pl
>>>>      Add new INSTALL_ABSOLUTE variable, remove duplicates.
>>> There are some comments at the top of the RULES_MODULES file but they
>>> were mostly intended for other applications that want to adopt the
>>> submodules scheme (the motor record uses it too).
>>> - Andrew
>>> Complexity is free, it's Simplicity that takes work.
Pierrick Hanlet
Fermi National Accelerator
Accelerator Front End Controls
+1-630-840-5555 -- lab
+1-312-687-4980 -- mobile
"Whether you think you can or think you can't, you're right" -- Henry Ford
Re: cross-compiling v7.0.7 Johnson, Andrew N. via Tech-talk
cross-compiling v7.0.7 Pierrick M Hanlet via Tech-talk
Re: cross-compiling v7.0.7 Andrew Johnson via Tech-talk
Re: cross-compiling v7.0.7 Pierrick M Hanlet via Tech-talk
Prev: Re: Issue installing StreamDevice on CentOS 7 Lang, Keenan C. via Tech-talk
Next: Re: Issue installing StreamDevice on CentOS 7 Han Lee via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: cross-compiling v7.0.7 Andrew Johnson via Tech-talk
Next: Re: cross-compiling v7.0.7 Johnson, Andrew N. via Tech-talk
