There is something unexpected in your environment then because the
file should be created properly — it is when everyone else runs
'make', and I'd like to work out what's different in your case; you
shouldn't have to resort to creating it manually, or to replacing
the RULES_MODULES file.
Do you happen to have an environment variable 'EPICS_BASE' set? Are
you providing any additional command-line parameters when you run
make? Do you have any files or a 'configure' directory in the parent
directory of where Base is installed? Do you set INSTALL_LOCATION in
any configure files?
- Andrew
On 6/15/23 1:56 PM, Pierrick M Hanlet
via Tech-talk wrote:
Greetings Andrew,
Oddly, even "make clean" creates the new file, so it's a bit of a
nuisance; I have to have one
terminal to run make and another one to update (copy a working version
of the RELEASE.linux-x86_64.local
file) after the build has started.
Interestingly, the v7.0.5 also has a RELEASE.linux-x86_64.local with
"EPICS_BASE = ", but
that did not adversely affect the build.
Note that we have no special build locations.
I'm running a test now, and it appears that if I use the v7.0.5
./configure/RULES_MODULES,
everything works as before.
Cheers,
Pierrick
On 6/15/23 10:49, Andrew Johnson via Tech-talk wrote:
Hi Pierrick,
On 6/15/23 6:07 AM, Pierrick M Hanlet via Tech-talk wrote:
Something broke, or I missed new instructions in building the modules in
v7.0.7 for cross-compiled platforms.
I'm building for several platforms. The host build is fine, but when
the cross-compiled platforms start building
a new RELEASE.linux-x86_64.local is created with "EPICS_BASE = ", i.e.
empty. I did not experience this with
v7.0.5.
Hopefully the fix should be to just delete that file and run 'make'
again in that directory, but if you have a more complex local build
process (e.g. if you're building on multiple host arch's) that might
need some modifications. How were you doing the cross-builds?
Getting the build rules right for generating the
modules/RELEASE.<host>.local file was tricky, and there were some
changes made to them between 7.0.5 and 7.0.7:
$ git log R7.0.5.. -- configure/RULES_MODULES
commit 098ee6c063c25c3b4483d7d5a0b6c8c6d8d17769
Author: Andrew Johnson <anj at anl.gov>
Date: Sat Sep 3 10:59:26 2022 -0500
Oops: Fix to RULES_MODULES
commit efc7cbaf7f93c1bc58f98b30b9d20a27bc0a7f91
Date: Fri Sep 2 14:10:27 2022 -0500
Build system fixes related to INSTALL_LOCATION
* The build can't descend into external submodules when there is no
configure/RULES_TOP file present in $(INSTALL_LOCATION).
* Recreate modules/RELEASE.<host>.local if configure/CONFIG_SITE or
configure/CONFIG_SITE.local have changed.
* Move the distclean of modules/RELEASE.<host>.local to RULES_TOP
* Several comment and white-space changes
commit 191ff137f17eecde9e836f0f9aeaec5eecb73b24
Date: Wed Nov 24 21:58:32 2021 -0600
configure: Use GNU Make's abspath instead of fullPathname.pl
Add new INSTALL_ABSOLUTE variable, remove duplicates.
There are some comments at the top of the RULES_MODULES file but they
were mostly intended for other applications that want to adopt the
submodules scheme (the motor record uses it too).
- Andrew
Complexity is free, it's Simplicity that takes work.
- Re: cross-compiling v7.0.7 Pierrick M Hanlet via Tech-talk
- cross-compiling v7.0.7 Pierrick M Hanlet via Tech-talk
- Re: cross-compiling v7.0.7 Andrew Johnson via Tech-talk
Issue installing StreamDevice on CentOS 7 Brandon Gunn via Tech-talk
Re: Issue installing StreamDevice on CentOS 7 Mark Rivers via Tech-talk
<2023>
2025
<2023>
2025
ANJ, 15 Jun 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
