Greetings Andrew,
Oddly, even "make clean" creates the new file, so it's a bit of a
nuisance; I have to have one
terminal to run make and another one to update (copy a working version
of the RELEASE.linux-x86_64.local
file) after the build has started.
Interestingly, the v7.0.5 also has a RELEASE.linux-x86_64.local with
"EPICS_BASE = ", but
that did not adversely affect the build.
Note that we have no special build locations.
I'm running a test now, and it appears that if I use the v7.0.5
./configure/RULES_MODULES,
everything works as before.
Cheers,
Pierrick
On 6/15/23 10:49, Andrew Johnson via Tech-talk wrote:
> Hi Pierrick,
> On 6/15/23 6:07 AM, Pierrick M Hanlet via Tech-talk wrote:
>> Something broke, or I missed new instructions in building the modules in
>> v7.0.7 for cross-compiled platforms.
>> I'm building for several platforms. The host build is fine, but when
>> the cross-compiled platforms start building
>> a new RELEASE.linux-x86_64.local is created with "EPICS_BASE = ", i.e.
>> empty. I did not experience this with
>> v7.0.5.
> Hopefully the fix should be to just delete that file and run 'make'
> again in that directory, but if you have a more complex local build
> process (e.g. if you're building on multiple host arch's) that might
> need some modifications. How were you doing the cross-builds?
> Getting the build rules right for generating the
> modules/RELEASE.<host>.local file was tricky, and there were some
> changes made to them between 7.0.5 and 7.0.7:
>> $ git log R7.0.5.. -- configure/RULES_MODULES
>> commit 098ee6c063c25c3b4483d7d5a0b6c8c6d8d17769
>> Author: Andrew Johnson <anj at anl.gov>
>> Date: Sat Sep 3 10:59:26 2022 -0500
>> Oops: Fix to RULES_MODULES
>> commit efc7cbaf7f93c1bc58f98b30b9d20a27bc0a7f91
>> Date: Fri Sep 2 14:10:27 2022 -0500
>> Build system fixes related to INSTALL_LOCATION
>> * The build can't descend into external submodules when there is no
>> configure/RULES_TOP file present in $(INSTALL_LOCATION).
>> * Recreate modules/RELEASE.<host>.local if configure/CONFIG_SITE or
>> configure/CONFIG_SITE.local have changed.
>> * Move the distclean of modules/RELEASE.<host>.local to RULES_TOP
>> * Several comment and white-space changes
>> commit 191ff137f17eecde9e836f0f9aeaec5eecb73b24
>> Date: Wed Nov 24 21:58:32 2021 -0600
>> configure: Use GNU Make's abspath instead of fullPathname.pl
>> Add new INSTALL_ABSOLUTE variable, remove duplicates.
> There are some comments at the top of the RULES_MODULES file but they
> were mostly intended for other applications that want to adopt the
> submodules scheme (the motor record uses it too).
> - Andrew
> Complexity is free, it's Simplicity that takes work.
Pierrick Hanlet
Fermi National Accelerator
Accelerator Front End Controls
+1-630-840-5555 -- lab
+1-312-687-4980 -- mobile
"Whether you think you can or think you can't, you're right" -- Henry Ford
- Re: cross-compiling v7.0.7 Andrew Johnson via Tech-talk
- cross-compiling v7.0.7 Pierrick M Hanlet via Tech-talk
Re: Issue installing asyn on CentOS 7 Brandon Gunn via Tech-talk
Issue installing StreamDevice on CentOS 7 Brandon Gunn via Tech-talk
<2023>
2025
<2023>
2025
