1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Re: Which VMEbus CPU for EPICS7 and RTEMS?
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: joel at rtems.org, Heinz Junkes <junkes at fhi-berlin.mpg.de>, Chris Johns <chrisj at rtems.org>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 21 Jun 2023 10:54:44 -0700
On 6/21/23 06:57, Joel Sherrill via Tech-talk wrote:
For NFSv4, you need libbsd which forces making sure there is
a driver and configuration for the board you care about.
Does the need to use libbsd effect the availability/function of
the existing PCI drivers for the VME bridge chips?
Some conversations I've listened in on leave me with the impression
that libbsd also includes the BSD PCI driver framework.  It is not
clear to me how this would interact with the RTEMS PCI driver
APIs which I am familiar with.
Re: Which VMEbus CPU for EPICS7 and RTEMS? Joel Sherrill via Tech-talk
Which VMEbus CPU for EPICS7 and RTEMS? Heinz Junkes via Tech-talk
Re: Which VMEbus CPU for EPICS7 and RTEMS? Zimoch Dirk via Tech-talk
Re: Which VMEbus CPU for EPICS7 and RTEMS? Heinz Junkes via Tech-talk
Prev: Re: MVME products discontinuation Mrinal Bera via Tech-talk
Next: Re: Which VMEbus CPU for EPICS7 and RTEMS? Joel Sherrill via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: Re: Which VMEbus CPU for EPICS7 and RTEMS? Joel Sherrill via Tech-talk
ANJ, 21 Jun 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
