Hello EPICS community! I'm writing a multi thread CA client test program to find the performance of CA put with softIOC using C language. My program is like this: preemptive_thread_handle_function() { ca_attach_context(pcaput_context); for (i = 0; i < pv_cnt; i++) { switch (pv's dbr_type) { case CHAR: ca_array_put(DBR_CHAR, 1, pCh, value); break; case SHORT: ca_array_put(DBR_SHORT, 1, pCh, value); break; case LONG: ca_array_put(DBR_LONG, 1, pCh, value); break; case FLOAT: ca_array_put(DBR_FLOAT, 1, pCh, value); break; case WAVEFORM: ca_array_put(DBR_CHAR, array_cnt, pCh, value); break; } } ca_flush_io(); } There are 3 threads to run this, and each thread's pv_cnt is ~3000. The main program is a infinite loop to schedule all the threads. After running for servel mininutes,strange time consumption occured during the for loop with no rules. The time measure code is like this: clock_t start, end; start = clock(); for (i = 0; i < pv_cnt; i++) {...} ca_flush_io(); end = clock(); double dt = (double)(end - start) / CLOCKS_PER_SEC; printf("create_pv dt=%lf\n", dt); In most time, the dt is ~0.002s, sometimes is ~0.015s. But suddenly, it becomes a number ~5.0s and I can see the camonitor within base/bin/win32-x86 suspend at the same time clearly. After that, it resumes ~0.002s. The 5.0s appeared 6 times in half an hour. EPICS base version is 3.15.8(win32_x86). My hardware is i7-3770, 8G RAM. The OS is Microsoft Windows 7_64bit and the dev IDE is Microsoft Visual Studio 2017. My test program used CPU ~25%(60s Ave) shown by the Windows Process Monitor.Before I run my test program, the softIoc.exe starts like this: softIoc.exe -D softIoc.dbd -d test1.db -d test2.db -d test3.db My question is: All the PVs' type and count are fixed, why CA put consumed different time? How to avoid 5.0s situation? Any hint and help will be appreciated. Thank you very much!
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
