1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Issue with streamdevice and I/o Intr
From: Florian Feldbauer via Tech-talk <[email protected]>
To: Zimoch Dirk <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 4 Jul 2023 13:31:51 +0200
Hey Dirk,
On 7/4/23 11:55, Zimoch Dirk wrote:
On Tue, 2023-07-04 at 11:09 +0200, Florian Feldbauer wrote:
Hey Dirk,
thanks for the detailed explanation.
I worked with StreamDevice and I/O intr a lot before, but always with
the asynSerialPort as lower level driver.
Just to be clear: Let's assume my input record with "I/O Intr" is the
only record reading on the bus, do I need to create a polling on the bus
myself or does StreamDevice internally create a polling thread?
StreamDevice does it automatically. In fact, ALL "I/O Intr" try to poll the bus.
The first one that gets the bus just cancels the poll of all others. This way,
the "I/O Intr" record with the fastest poll rate is effectively the one which
does the polling.
Thx for the advice with the eomReason, I changed my driver accordingly.
My protocol and record now look like this:
Terminator = '';
recv {
    MaxInput = 4;
    in  0x07 $1 "%r";
record( longin, "CAN${N}:TEST:R" ) {
    field( DTYP, "stream" )
    field( SCAN, "I/O Intr" )
    field( INP,  "@can.proto recv(0x00) ${port}" )
Your protocol expects 3 bytes, 0x07 0x00 and one byte data. But it received 4
bytes, 0x07 0x00 0x00 0x15. Thus one byte is left and makes the protocol fail.
Using %2r should give you the signed 16 bit integer value 0x0015.
Oh, ok, I thought "%r" would read up to 4 bytes and not just one.
I should read the doc more carefully. I updated the protocol accordingly.
The first two bytes contain the 11bit CAN arbitration ID followed by the
up to 8 data bytes.
We have one device that sends 32bit floats via CAN bus, which is why we
use the raw format, so we can parse those values later with the %R
format converter.
Be aware that %r and %R both cannot fail and thus only the input length can
distinguish between the two formats. You will not be able to separate %4r from
%4R if the first two bytes are the same.
Yes, I'm aware of this, but the first 2 bytes (CAN bus arbitration ID) will be unique for each device on the bus and also later on the data bytes will contain specific information on which type of data we received.
The current protocol is just for a very simple testing procedure.
I find it strange that in the log below you send 4 bytes (0x07 0x00 0x00 0x15)
but receive 5 (0x07 0x00 0x00 0x15 0x00). Is everything correct in your driver?
The additional 0x00 at the end was due to a bug I introduced when setting eomReason to ASYN_EOM_END. This is now fixed and I get 0x07 0x00 0x00 0x15 from the driver. Unfortunately everything else stayed the same.
I still don't see messages from asynReadHandler. Strange. Does your driver not
pass the data through asynOctetBase? Look how drvAsynSerialPort links to
asynOctetBase in drvAsynSerialPortConfigure: pasynOctetBase->initialize()
I wrote my driver as a derived class from the AsynPortDriver, overloading the read/write Octet methods.
473 drvAsynCAN::drvAsynCAN( char const* portName, char const* interface, int autoConnect ) :
474   asynPortDriver( portName,
475                   0, // maxAddr
476                   asynCommonMask | asynOctetMask | asynDrvUserMask, // Interface mask
477                   asynCommonMask | asynOctetMask,  // Interrupt mask
478                   ASYN_CANBLOCK, // asynFlags
479                   autoConnect,  // Autoconnect
480                   0,   // Default priority
481                   0 ), // Default stack size
482   fd_(-1)
483 {
The constructor of the base class calls the pasynOctetBase->initialize() method.
  Florian
If not using pasynOctetBase, your read function will not call
callInterruptUsers() unless you explicitly do it yourself and thus "I/O Intr"
records will not receive anything.
Dirk
My IOC has 2 CAN interfaces and I was trying to send a frame from can0
to can1 or vise versa.
Here is the complete log from Stream:
epics> dbpf CAN0:TEST:W 21
2023/07/04 11:03:07.127321 _main_ StreamEpics.cc:908:
Stream::process(CAN0:TEST:W)
2023/07/04 11:03:07.127508 _main_ StreamEpics.cc:934:
Stream::process(CAN0:TEST:W) start
2023/07/04 11:03:07.127628 _main_ StreamCore.cc:429:
StreamCore::startProtocol(CAN0:TEST:W, startMode=StartNormal)
2023/07/04 11:03:07.127725 _main_ StreamCore.cc:564:
StreamCore::evalCommand(CAN0:TEST:W): activeCommand = out
2023/07/04 11:03:07.127828 _main_ StreamCore.cc:689:
StreamCore::formatOutput(CAN0:TEST:W): format = %.2r
2023/07/04 11:03:07.127945 _main_ StreamEpics.cc:1173:
Stream::formatValue(CAN0:TEST:W, format=%r, fieldaddr=(nil)
2023/07/04 11:03:07.128054 _main_ StreamEpics.cc:1298:
Stream::formatValue(CAN0:TEST:W) format=%r type=DBF_LONG
2023/07/04 11:03:07.128166 _main_ StreamEpics.cc:693:
streamPrintf(CAN0:TEST:W,format=%r)
2023/07/04 11:03:07.128284 _main_ StreamCore.cc:777:
StreamCore::printValue(CAN0:TEST:W, %r, 21 = 0x15): "<07><00><00><15>"
2023/07/04 11:03:07.128402 _main_ StreamCore.cc:612:
StreamCore::evalOut: outputLine = "<07><00><00><15>"
2023/07/04 11:03:07.128503 _main_ StreamCore.cc:623:
StreamCore::evalOut(CAN0:TEST:W): lockRequest(5000)
2023/07/04 11:03:07.128599 _main_ AsynDriverInterface.cc:549:
AsynDriverInterface::lockRequest(CAN0:TEST:W, 5000 msec)
2023/07/04 11:03:07.128739 _main_ StreamEpics.cc:948:
Stream::process(CAN0:TEST:W): protocol started
2023/07/04 11:03:07.128794 can0 AsynDriverInterface.cc:590:
AsynDriverInterface::lockHandler(CAN0:TEST:W)
DBF_LONG:           21 = 0x15
2023/07/04 11:03:07.129004 can0 StreamCore.cc:832:
StreamCore::lockCallback(CAN0:TEST:W, StreamIoSuccess)
2023/07/04 11:03:07.129122 can0 AsynDriverInterface.cc:627:
AsynDriverInterface::writeRequest(CAN0:TEST:W, "<07><00><00><15>", 300 msec)
epics> 2023/07/04 11:03:07.129265 can0 AsynDriverInterface.cc:649:
AsynDriverInterface::writeHandler(CAN0:TEST:W)
2023/07/04 11:03:07.129375 can0 AsynDriverInterface.cc:667:
AsynDriverInterface::writeHandler(CAN0:TEST:W): reading old input
2023/07/04 11:03:07.130 can0: wrote 4 bytes to can0, return asynSuccess
2023/07/04 11:03:07.129714 can0 AsynDriverInterface.cc:715:
AsynDriverInterface::writeHandler(CAN0:TEST:W): write(...,
"<07><00><00><15>", outputSize=4, written=4) [timeout=0.3 sec] =
asynSuccess
2023/07/04 11:03:07.129844 can0 StreamCore.cc:877:
StreamCore::writeCallback(CAN0:TEST:W, StreamIoSuccess)
2023/07/04 11:03:07.129948 can0 StreamCore.cc:564:
StreamCore::evalCommand(CAN0:TEST:W): activeCommand = end
2023/07/04 11:03:07.130403 can0 StreamCore.cc:465:
StreamCore::finishProtocol(CAN0:TEST:W, Success) bus owner
2023/07/04 11:03:07.130508 can0 AsynDriverInterface.cc:610:
AsynDriverInterface::unlock(CAN0:TEST:W)
2023/07/04 11:03:07.130606 can0 AsynDriverInterface.cc:1468:
AsynDriverInterface::finish(CAN0:TEST:W) start
2023/07/04 11:03:07.130697 can0 AsynDriverInterface.cc:1478:
AsynDriverInterface::finish(CAN0:TEST:W) done
2023/07/04 11:03:07.130792 can0 StreamEpics.cc:1034:
Stream::protocolFinishHook(CAN0:TEST:W, Success)
2023/07/04 11:03:07.130967 cbLow StreamEpics.cc:1112:
recordProcessCallback(CAN0:TEST:W) processing record
2023/07/04 11:03:07.131135 cbLow StreamEpics.cc:908:
2023/07/04 11:03:07.131230 cbLow StreamEpics.cc:922:
Stream::process(CAN0:TEST:W) ready. don't convert
2023/07/04 11:03:07.131344 cbLow StreamEpics.cc:1116:
recordProcessCallback(CAN0:TEST:W) processing record done
2023/07/04 11:03:07.484 can1: read 5 bytes from can1, return asynSuccess
2023/07/04 11:03:07.483786 can1 AsynDriverInterface.cc:951:
AsynDriverInterface::readHandler(CAN1:TEST:R): ioAction=AsyncRead read(4
bytes, timeout=0 sec) returned status asynSuccess: received=5 bytes,
eomReason=END, buffer="<07><00><00><15><00>"
2023/07/04 11:03:07.483917 can1 AsynDriverInterface.cc:977:
AsynDriverInterface::readHandler(CAN1:TEST:R): AsyncRead poll: received
5 of 4 bytes "<07><00><00><15><00>" eomReason=END [data ignored]
2023/07/04 11:03:07.484024 can1 AsynDriverInterface.cc:1123:
AsynDriverInterface::readHandler(CAN1:TEST:R) readMore=-1 bytesToRead=63
2023/07/04 11:03:07.484160 can1 AsynDriverInterface.cc:951:
read(63 bytes, timeout=0.5 sec) returned status asynTimeout: received=0
bytes, eomReason=NONE, buffer=""
2023/07/04 11:03:07.484273 can1 AsynDriverInterface.cc:1051:
AsynDriverInterface::readHandler(CAN1:TEST:R): ioAction=AsyncRead,
timeout [0.5 sec] after 0 of 63 bytes ""
2023/07/04 11:03:07.484397 can1 StreamCore.cc:963:
StreamCore::readCallback(CAN1:TEST:R, StreamIoTimeout input="", size=0)
2023/07/04 11:03:07.484504 can1 StreamCore.cc:1015:
StreamCore::readCallback(CAN1:TEST:R) inputBuffer="", size 0
2023/07/04 11:03:07.484806 can1 StreamCore.cc:1108:
StreamCore::readCallback(CAN1:TEST:R) async timeout: just restart
2023/07/04 11:03:07.484975 can1 AsynDriverInterface.cc:806:
AsynDriverInterface::readRequest(CAN1:TEST:R, 500 msec reply, 500 msec
read, expect 4 bytes, async=yes)
2023/07/04 11:03:07.485125 can1 AsynDriverInterface.cc:831:
AsynDriverInterface::readRequest CAN1:TEST:R: queueRequest(...,
priority=0, queueTimeout=-1 sec) = asynSuccess [async=true]
Setting eomReason to ASYN_EOM_END seems to attach a 0 to the received
data, but it still should match the %r format converter.
Cheres,
Florian
On 7/4/23 10:45, Zimoch Dirk wrote:
Hi Florian,
For "I/O Intr" records, StreamDevice uses intrCallbackOctet but still needs to
poll the device, because despite its name, intrCallbackOctet does not deliver
any data asynchronously when nobody reads synchronously. The "I/O Intr" records
receives ALL input, regardless of the active reader, which may be the record
itself, some other StreamDevice Record or even non-StreamDevice records or any
other software calling asynOctet->read on that port.
Thus, to avoid receiving the data twice, in case the intrCallbackOctet receiver
is the polling record, StreamDevice discards the input received with the polled
read and only uses the input received with intrCallbackOctet.
As ALL "I/O Intr" StreamDevice records receive ALL input, they all match the
input against their 'in' commands. Only those records  which could match the
input successfully are processed. All others silently ignore the input!
The intrCallbackOctet input log messages should show up in the logs BEFORE the
message form the polled read (because asyn calls the interrupt callbacks before
returning from read). What do you have in the logs right before the first line
you posted? Anything from AsynDriverInterface::asynReadHandler() and
StreamCore::readCallback()?
As StreamDevice did not receive a termination signal, it assumes there may be
more input and tries to read it. But that results in a timeout, which is then
interpreted as a termination signal, because no InTerminator is used.
This is probably not what you want. If the message never exceeds one CAN frame,
set eomReason to ASYN_EOM_END. This avoids wasting time on another read attempt.
If you may have messages that span multiple frames and have a method to find out
when this is the case in your driver, do that. Otherwise waiting for timeout (or
InTerminator or maxInput) is in fact the only way.
Now the question is why the input is rejected. Hard to say without knowing your
protocol. What do you have in your 'in' command?
Dirk
On Tue, 2023-07-04 at 09:05 +0200, Florian Feldbauer via Tech-talk wrote:
Hey all,
we have some devices controlled via CAN bus.
Since CAN bus is based on the transmission of 1-8 bytes, I wrote an
AsynPortDriver with an asynOctet interface as lower level driver.
I wanted to use StreamDevice as higher level driver defining the actual
payload data that is tranmitted between our PC and the devices.
Sending and receiving messages in principal works, but I have an issue
with I/O Interrupts and I don't know why.
Setting the streamDebug variable to 1, I see the following output from
StreamDevice:
2023/07/04 08:54:44.301618 can1 AsynDriverInterface.cc:951:
read(63 bytes, timeout=0 sec) returned status asynSuccess: received=4
bytes, eomReason=NONE, buffer="<07><00><00><ea>"
2023/07/04 08:54:44.301765 can1 AsynDriverInterface.cc:977:
4 of 63 bytes "<07><00><00><ea>" eomReason=NONE [data ignored]
2023/07/04 08:54:44.301889 can1 AsynDriverInterface.cc:1123:
2023/07/04 08:54:44.302015 can1 AsynDriverInterface.cc:951:
2023/07/04 08:54:44.302140 can1 AsynDriverInterface.cc:1051:
2023/07/04 08:54:44.302262 can1 StreamCore.cc:963:
2023/07/04 08:54:44.302378 can1 StreamCore.cc:1015:
2023/07/04 08:54:44.302490 can1 StreamCore.cc:1067:
StreamCore::readCallback(CAN1:TEST:R) end flag received
2023/07/04 08:54:44.302605 can1 StreamCore.cc:1127:
StreamCore::readCallback(CAN1:TEST:R) input line: ""
2023/07/04 08:54:44.302726 can1 StreamCore.cc:1151:
StreamCore::readCallback(CAN1:TEST:R) async match failure: just restart
2023/07/04 08:54:44.302847 can1 AsynDriverInterface.cc:806:
read, expect 0 bytes, async=yes)
2023/07/04 08:54:44.302964 can1 AsynDriverInterface.cc:831:
The readHandler reads the message from the bus but ignores it. According
to the comments in the code it is ignored because the asyncReadHandler
should also receive this message and handle the I/O interrupt, but it
seems the Interrupt callback is not executed.
Any idea why the callbacks don't work?
I'm using
base 7.0.6.1
stream 2.8.24
asyn (current HEAD on master branch)
Cheers,
Florian
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
Issue with streamdevice and I/o Intr Florian Feldbauer via Tech-talk
Re: Issue with streamdevice and I/o Intr Zimoch Dirk via Tech-talk
Re: Issue with streamdevice and I/o Intr Florian Feldbauer via Tech-talk
Prev: Re: Issue with streamdevice and I/o Intr Zimoch Dirk via Tech-talk
Next: Machine learning using EPICS Kuldeep Joshi via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: RE : VME configuration : mrfioc2-master version in the new vme-evg-300, vme-evr-300 environment 이민균 via Tech-talk
