1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Record process when restore using autosave
To: tech-talk <[email protected]>
Date: Fri, 7 Jul 2023 09:53:28 +0800 (GMT+08:00)
Hi all,
 I need the records process in order to write the restored value to hardware when reboot the IOC using autosave module. It said "Restoring at run time can produce a different result than restoring at boot time, because record processing may occur." in the manual. But how? Any suggestion or advice would be great apprecaited
Cheers,
Xuan
Re: Record process when restore using autosave Ralph Lange via Tech-talk
Prev: Error in alarm-logger.sh Eusebio Naif Al-Soliman Fuentes via Tech-talk
Next: Re: Re: [EXTERNAL] Re: Re: Question about fetching history data from MySQL by using phoebus lzfneu--- via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Error in alarm-logger.sh Eusebio Naif Al-Soliman Fuentes via Tech-talk
Next: Re: Record process when restore using autosave Ralph Lange via Tech-talk
