1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Error in alarm-logger.sh
From: Eusebio Naif Al-Soliman Fuentes via Tech-talk <[email protected]>
To: Tech Talk <[email protected]>
Date: Fri, 07 Jul 2023 10:12:19 +0200
Hello Giovanni.
Your dockerized solution looks awesome, I'll give it a try.
It's also important to consider the compatibility between versions of Elasticsearch and the alarm-logger, maybe that's the problem in my setup. If I have any issues or doubts, I'll tell you.
Thank you so much, Eusebio.
Saludos/Best regards
University of Granada
MSc. Data Science and Computer Engineering
[email protected]
El 2023-07-07 09:13, Giovanni Savarese LNL escribió:
I've worked on the same problem at the beginning of this year and what I understood is that not all phoebus alarm logger versions work well with all versions of elasticsearch. Also I noticed that to work with the provided alarm logger version some changes on the service port number are required (8080 instead 9000 if I remember correctly).
So far I tried different solutions and at this link https://urldefense.com/v3/__https://github.com/giosava94/docker-phoebus-alarm__;!!D9dNQwwGXtA!VQTXyYP93HbjA771MJwWKCxVLXkklNkRWJnnGOg0o76LM0RO4SbOdSG33VeKIGCgROVcmyv3sss6KmE7v5UBSjyIH6XbjOKtgQ$  you can find my dockerized solution.
I hope it helps you.
Giovanni S
PS I did not try your configuration. I just give you some material for reference.
On 06/07/23 22:10, Eusebio Naif Al-Soliman Fuentes via Tech-talk wrote:
Hello everyone.
I have CSS-Phoebus working fine with the alarm-server (Kafka and Zookeeper are also working fine). However, I have encountered an issue while attempting to start the alarm-logger.sh service.
To provide some context, I am using Docker to run Elasticsearch and Kibana. Below it's the docker-compose file that I have been using to start these services:
version: "3.0"
services:
  elasticsearch:
    container_name: es-container
    image: docker.elastic.co/elasticsearch/elasticsearch:8.2.3
    environment:
      - xpack.security.enabled=false
      - "discovery.type=single-node"
    networks:
      - elastic
    ports:
      - 9200:9200
  kibana:
    container_name: kb-container
    image: docker.elastic.co/kibana/kibana:8.2.3
    environment:
      - ELASTICSEARCH_HOSTS=https://urldefense.com/v3/__http://es-container:9200__;!!D9dNQwwGXtA!VQTXyYP93HbjA771MJwWKCxVLXkklNkRWJnnGOg0o76LM0RO4SbOdSG33VeKIGCgROVcmyv3sss6KmE7v5UBSjyIH6U8l-bUYA$     networks:
      - elastic
    depends_on:
      - elasticsearch
    ports:
      - 5601:5601
networks:
  elastic:
    driver: bridge
I downloaded the alarm-logger from the following link: https://urldefense.com/v3/__https://controlssoftware.sns.ornl.gov/css_phoebus/nightly/__;!!D9dNQwwGXtA!VQTXyYP93HbjA771MJwWKCxVLXkklNkRWJnnGOg0o76LM0RO4SbOdSG33VeKIGCgROVcmyv3sss6KmE7v5UBSjyIH6WpBmqkqg$ When I try to launch the alarm-logger by running 'sh alarm-logger.sh' in the console, I encounter the following error logs:
2023-07-06 21:54:41 INFORMACIÓN [org.phoebus.alarm.logging.AlarmLoggingService] Alarm Logging Service (PID 14002)
jul 06, 2023 9:54:42 P. M. org.phoebus.framework.preferences.PreferencesReader <init>
GRAVE: Cannot read default preference settings for class org.phoebus.alarm.logging.AlarmLoggingService from /alarm_logging_service.properties
Commands:
    help             - Show help.
    shutdown         - Shut alarm logger down and exit.
 > jul 06, 2023 9:54:42 P. M. org.apache.kafka.common.config.AbstractConfig logUnused
ADVERTENCIA: The configuration 'admin.retries' was supplied but isn't a known config.
jul 06, 2023 9:54:43 P. M. org.elasticsearch.client.RequestLogger logResponse
ADVERTENCIA: request [PUT https://urldefense.com/v3/__http://localhost:9200/_template/alarms_state_template?master_timeout=30s&include_type_name=true&create=true__;!!D9dNQwwGXtA!VQTXyYP93HbjA771MJwWKCxVLXkklNkRWJnnGOg0o76LM0RO4SbOdSG33VeKIGCgROVcmyv3sss6KmE7v5UBSjyIH6XyAjeY-Q$ ] returned 1 warnings: [299 Elasticsearch-8.2.3-9905bfb62a3f0b044948376b4f607f70a8a151b4 "Legacy index templates are deprecated in favor of composable templates."]
I have been troubleshooting the issue, but so far, I haven't been able to resolve it. If anyone has any insights or suggestions on how to fix this issue, I would greatly appreciate your assistance.
Maybe the issue is related to the configuration.
Thank you for your attention.
-- Saludos/Best regards
*University of Granada *
*MSc. Data Science and Computer Engineering*__
[email protected]
Error in alarm-logger.sh Eusebio Naif Al-Soliman Fuentes via Tech-talk
Re: Error in alarm-logger.sh Giovanni Savarese LNL via Tech-talk
Prev: RE: interrupt read data in int32Driver example GAGET Alexis via Tech-talk
Next: Re: interrupt read data in int32Driver example timesir via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Error in alarm-logger.sh Giovanni Savarese LNL via Tech-talk
Next: Record process when restore using autosave 吴煊 via Tech-talk
