1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: interrupt read data in int32Driver example
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Fri, 7 Jul 2023 11:27:09 +0200
On Fri, 7 Jul 2023 at 10:19, timesir via Tech-talk <[email protected]> wrote:
Your response is greatly appreciated and has been very helpful. Thank you.
However, I still want to know how to simulate interrupt reads through software in the official int32Driver example.
The EPICS simulation mode can be used to do that - this is implemented in the database, so it works for all records, not just for those using the ASYN framework.
For details see the paragraph "Input Simulation Fields" in the Record Reference Manual at https://epics.anl.gov/base/R7-0/7-docs/dbCommonInput.html
Cheers,
~Ralph
interrupt read data in int32Driver example timesir via Tech-talk
RE: interrupt read data in int32Driver example GAGET Alexis via Tech-talk
Re: interrupt read data in int32Driver example timesir via Tech-talk
Prev: Re: Record process when restore using autosave Ralph Lange via Tech-talk
Next: Macro max size is 256 TZVETKOV Stephane via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: interrupt read data in int32Driver example timesir via Tech-talk
Next: Re: interrupt read data in int32Driver example Mark Rivers via Tech-talk
