1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: issue of getTimeStamp from EVR
From: "Shen, Guobao via Tech-talk" <[email protected]>
To: Di Wang <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 7 Jul 2023 12:55:00 +0000
Di,
  • every record calls getTimeStamp() to read timestamp from EVR
If your purpose is to get a time stamp for every record in your IOC, there are a few way to do it.
One way is as you are doing to have every record to do an IO reading from your EVR hardware, which could be expensive.
Especially, in your case, 300 IO interrupts at 50Hz (20ms cycle).
Not sure about your Linux, whether you are using a RT Linux, or a general one. If general one, whether you have the RT kernel function included/enabled.
But your testing result with perf does match your description, that the majority of your CPU is on IO timestamp processing.
Another way is to have one root record to get the timestamp from your EVR, instead of, and distribute them to the other 300 records.
Guobao
From: Tech-talk <[email protected]> on behalf of Di Wang via Tech-talk <[email protected]>
Date: Friday, July 7, 2023 at 1:44 AM
To: [email protected] <[email protected]>
Subject: issue of getTimeStamp from EVR
I have a Linux IOC connecting to a PXIe chassis. The IOC is triggered by
a PXI EVR at 50 Hz. About 300 records are processed every 20 ms.
Sometimes the IOC misses the trigger.
When I analyze the IOC overhead using `perf`, I find that the usage of
getTimeStamp function from mrfioc2 is very high (see below). Then I use
`perf annotate` to check getTimeStamp() and I find the CPU is waiting
for below instructions. So I think the main reason is that the reading
time from EVR takes too long.
https://github.com/epics-modules/mrfioc2/blob/master/evrMrmApp/src/drvem.cpp#L801-L818
// Get current absolute time
epicsUInt32 ctrl=READ32(base, Control);
// Latch timestamp
WRITE32(base, Control, ctrl|Control_tsltch);
ts.secPastEpoch=READ32(base, TSSecLatch);
ts.nsec=READ32(base, TSEvtLatch);
epicsUInt32 ctrl2=READ32(base, Control);
As a General Time Provider, the EVR has the highest priority, it is
nature that every record calls getTimeStamp() to read timestamp from EVR.
Is such pciread latency normal?  How to solve it? Or should I increase
the OS Clock priority to avoid calling getTimeStamp()?
Cheers,
Di WANG
KEK
epics> generalTimeReport
Backwards time errors prevented 0 times.
Current Time Providers:
  "EVR", priority = 50
   Current Time is 2023-07-06 19:28:39.738546.
  "OS Clock", priority = 999
   Current Time is 2023-07-06 19:28:39.738719.
Event Time Providers:
# perf report
overhead  Command          Shared Object          Symbol
   45.26%  cbLow            libevrMrm.so.2.3       [.] EVRMRM::getTimeStamp
   11.60%  CAS-event        libevrMrm.so.2.3       [.] EVRMRM::getTimeStamp
    3.32%  cbHigh           libevrMrm.so.2.3       [.] mrmBufRx::drainbuf
    2.26%  cbHigh           libevrMrm.so.2.3       [.] EVRMRM::getTimeStamp
    1.85%  cbLow            libc.so.6              [.]
__memmove_avx_unaligned_erms
    1.76%  CAS-UDP          libevrMrm.so.2.3       [.] EVRMRM::getTimeStamp
    1.28%  CAS-event        [kernel.kallsyms]      [k]
syscall_return_via_sysret
    1.00%  CAS-event        [kernel.kallsyms]      [k]
entry_SYSCALL_64_after_hwframe
Samples: 95K of event 'cycles', 4000 Hz, Event count (approx.): 84846615925
/home/acc/epics/R3.15.9/modules/mrfioc2-2.3.0/lib/linux-x86_64/libevrMrm.so.2.3
[Percent: local period]
   0.00 │    → callq EVRMRM::convertTS@plt
   0.00 │      mov   %eax,%r13d
        │      test  %al,%al
        │    ↓ je    90
   0.02 │      mov   0x8(%rsp),%rax
   0.01 │      mov   %rax,(%r12)
        │    ↓ jmp   93
        │      nop
        │90:   xor   %r13d,%r13d
        │93:   mov   %r14,%rdi
        │    → callq epicsMutex::unlock@plt
   0.00 │      add   $0x10,%rsp
        │      mov   %r13d,%eax
   0.01 │      pop   %rbx
   0.00 │      pop   %rbp
   0.01 │      pop   %r12
        │      pop   %r13
        │      pop   %r14
        │    ← retq
        │      nop
        │b0:   mov   0xe8(%rbp),%rax
  24.10 │      mov   0x4(%rax),%ebx
   0.04 │      mov   %ebx,%edx
   0.00 │      or    $0x4,%dh
   0.01 │      mov   %edx,0x4(%rax)
  26.23 │      mov   0x68(%rax),%edx
   0.08 │      mov   %edx,0x8(%rsp)
  25.25 │      mov   0x6c(%rax),%edx
   0.06 │      mov   %edx,0xc(%rsp)
  24.03 │      mov   0x4(%rax),%edx
   0.03 │      cmp   %ebx,%edx
issue of getTimeStamp from EVR Di Wang via Tech-talk
Prev: Re: interrupt read data in int32Driver example Mark Rivers via Tech-talk
Next: Re: [EXTERNAL] phoebus Tank widget: Limits from PV? Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: issue of getTimeStamp from EVR Di Wang via Tech-talk
Next: Re: issue of getTimeStamp from EVR Michael Davidsaver via Tech-talk
