1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: issue of getTimeStamp from EVR
To: Timo Korhonen <[email protected]>, "[email protected]" <[email protected]>, [email protected]
Date: Fri, 7 Jul 2023 22:45:10 +0900
Hi Timo, Guobao,
Thanks very much for your comments.
As for my setup, I am using a commercial PC with AlmaLinux 9.2 installed (kernel version is 5.14, RT kernel is enabled and tuned for high throughput performance). The IOC also uses MCoreUtils module to set the CPU affinity, schedule policy and priority.
For the hardware part, it uses NI PXIe-8381 to connect to the PXIe-1082 chassis. As you said, reading the timestamp from PCIe registers should be very quick. So I suspect that the latency may be caused from the PXIe-8381 module. I plan to measure it later.
For the usage of timestamp, actually I simply use it to diagnose the processing order of records during early stage. For the final operation, only one root record reading the EVR timestamp and other records inherit the timestamp using TSEL should suffice.
Cheers,
Di WANG
KEK
On 7/7/2023 8:15 PM, Timo Korhonen wrote:
I would like to see a few more details about your setup. In principle, reading the timestamp from PCIe registers should be very quick.
However, I am wondering if all of your 300 records really need an individual hardware timestamp, like your description seems to suggest.
I would imagine that you have a handful of events going on and you would like to know when those happened and timestamp your records with those times.
If you use the code to get the current absolute time, as it seems, you will in effect get a precise time when the software was processing your record.
I think that this is probably not what you actually want?
The other observation is that you appear to have a lot of records in the "cbLow" thread...that might also be worth to take a look. It could be the reason for the IOC missing triggers.
Based on how I interpret your case, I would suggest that you change timestamping to happen based on the events.
In addition, please consider if you can use TSEL to point to some "root" record that gets the timestamp from the event of interest.
My interpretation can of course be wrong and you indeed want to record the event processing times, or something in that direction. In that case, please let me know and we can take a new look.
I would not change the OS clock priority just yet.
Best regards,
Timo
On 2023-07-07, 08:44, "Tech-talk on behalf of Di Wang via Tech-talk" <[email protected] <mailto:[email protected]> on behalf of [email protected] <mailto:[email protected]>> wrote:
I have a Linux IOC connecting to a PXIe chassis. The IOC is triggered by
a PXI EVR at 50 Hz. About 300 records are processed every 20 ms.
Sometimes the IOC misses the trigger.
When I analyze the IOC overhead using `perf`, I find that the usage of
getTimeStamp function from mrfioc2 is very high (see below). Then I use
`perf annotate` to check getTimeStamp() and I find the CPU is waiting
for below instructions. So I think the main reason is that the reading
time from EVR takes too long.
https://github.com/epics-modules/mrfioc2/blob/master/evrMrmApp/src/drvem.cpp#L801-L818 <https://github.com/epics-modules/mrfioc2/blob/master/evrMrmApp/src/drvem.cpp#L801-L818>
// Get current absolute time
epicsUInt32 ctrl=READ32(base, Control);
// Latch timestamp
WRITE32(base, Control, ctrl|Control_tsltch);
ts.secPastEpoch=READ32(base, TSSecLatch);
ts.nsec=READ32(base, TSEvtLatch);
epicsUInt32 ctrl2=READ32(base, Control);
As a General Time Provider, the EVR has the highest priority, it is
nature that every record calls getTimeStamp() to read timestamp from EVR.
Is such pciread latency normal? How to solve it? Or should I increase
the OS Clock priority to avoid calling getTimeStamp()?
Cheers,
Di WANG
KEK
epics> generalTimeReport
Backwards time errors prevented 0 times.
Current Time Providers:
"EVR", priority = 50
Current Time is 2023-07-06 19:28:39.738546.
"OS Clock", priority = 999
Current Time is 2023-07-06 19:28:39.738719.
Event Time Providers:
# perf report
overhead Command Shared Object Symbol
45.26% cbLow libevrMrm.so.2.3 [.] EVRMRM::getTimeStamp
11.60% CAS-event libevrMrm.so.2.3 [.] EVRMRM::getTimeStamp
3.32% cbHigh libevrMrm.so.2.3 [.] mrmBufRx::drainbuf
2.26% cbHigh libevrMrm.so.2.3 [.] EVRMRM::getTimeStamp
1.85% cbLow libc.so.6 [.]
__memmove_avx_unaligned_erms
1.76% CAS-UDP libevrMrm.so.2.3 [.] EVRMRM::getTimeStamp
1.28% CAS-event [kernel.kallsyms] [k]
syscall_return_via_sysret
1.00% CAS-event [kernel.kallsyms] [k]
entry_SYSCALL_64_after_hwframe
Samples: 95K of event 'cycles', 4000 Hz, Event count (approx.): 84846615925
/home/acc/epics/R3.15.9/modules/mrfioc2-2.3.0/lib/linux-x86_64/libevrMrm.so.2.3
[Percent: local period]
0.00 │ → callq EVRMRM::convertTS@plt
0.00 │ mov %eax,%r13d
│ test %al,%al
│ ↓ je 90
0.02 │ mov 0x8(%rsp),%rax
0.01 │ mov %rax,(%r12)
│ ↓ jmp 93
│ nop
│90: xor %r13d,%r13d
│93: mov %r14,%rdi
│ → callq epicsMutex::unlock@plt
0.00 │ add $0x10,%rsp
│ mov %r13d,%eax
0.01 │ pop %rbx
0.00 │ pop %rbp
0.01 │ pop %r12
│ pop %r13
│ pop %r14
│ ← retq
│ nop
│b0: mov 0xe8(%rbp),%rax
24.10 │ mov 0x4(%rax),%ebx
0.04 │ mov %ebx,%edx
0.00 │ or $0x4,%dh
0.01 │ mov %edx,0x4(%rax)
26.23 │ mov 0x68(%rax),%edx
0.08 │ mov %edx,0x8(%rsp)
25.25 │ mov 0x6c(%rax),%edx
0.06 │ mov %edx,0xc(%rsp)
24.03 │ mov 0x4(%rax),%edx
0.03 │ cmp %ebx,%edx
issue of getTimeStamp from EVR Di Wang via Tech-talk
Re: issue of getTimeStamp from EVR Timo Korhonen via Tech-talk
Prev: Re: Looking for LV-EPICS BIndings CALab Installer, Looking for OceanOpics Spectrometer Driver Tomasz Brys via Tech-talk
Next: Re: issue of getTimeStamp from EVR Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: issue of getTimeStamp from EVR Timo Korhonen via Tech-talk
Next: Re: issue of getTimeStamp from EVR Shen, Guobao via Tech-talk
