Hi Stéphane,
On 7/7/23 4:49 AM, TZVETKOV Stephane
via Tech-talk wrote:
I somehow found out that the associated NORD field was always limited to 256, and that my string was always cropped to 256 characters. It took me some time to actually understand that the limitation was that an EPICS macro has a maximum size of 256 characters.
(by the way, I also discovered that the name of a macro is also limited to 256 characters)
In order to work around this limitation, I just recompiled the EPICS base with a minor modification in `modules/libcom/src/macLib/macLib.h`. E.g., changing the maximum size from 256 to 65535:
vi modules/libcom/src/macLib/macLib.h
~ > #define MAC_SIZE 65535
As far as I have tested, this modification didn't seem to cause any problem. But, I wonder if more experienced EPICS developers have comments about this. Maybe increasing macro size has side effects that I didn't anticipated. Maybe there is a cleaner/better way to do this.
I'm not aware of any unwanted side-effects of doing that, the macLib
code uses that setting internally, and the API ensures the code
always knows the capacity of any buffer it's writing into so it
won't overrun external buffers.
However I don't think using 65535 there would allow for that size of
string values in the database as there are some other places in the
code that still use smaller fixed-size buffers, for example:
1. The modules/database/src/ioc/dbStatic/dbLexRoutines.c code that
parses and loads .db and .dbd files uses fixed-size 1024-byte
buffers (change MY_BUFFER_SIZE in that file).
2. The msi program uses 4096-byte buffers, you'd need to change
MAX_BUFFER_SIZE in modules/database/src/ioc/dbtemplate/msi.cpp to
increase them if you use msi to expand substitution files with large
strings.
3. The lexical scanners generated by flex seem to use 8192 and 16384
byte buffers by default, thus the largest string that the .db file
parser can read might be a few characters less than one of those two
sizes.
There might be some other places too, if you try fixing the ones
above please let us know any more that you come across — it would be
good to at least document where our code limits the string sizes,
and the idea of unifying them all could be interesting.
HTH,
- Andrew
Complexity is free, it's Simplicity that takes work.
- Macro max size is 256 TZVETKOV Stephane via Tech-talk
Re: issue of getTimeStamp from EVR Ralph Lange via Tech-talk
Re: Sequencer usage/Is sequencer repo still down? Michael Davidsaver via Tech-talk
<2023>
2025
2026
changing compiler versions Pierrick M Hanlet via Tech-talk
<2023>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
