1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: RE: Question on Accessing Data in Custom PV Structures
From: "Srinivas, Dhruv via Tech-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 10 Jul 2023 15:18:42 +0000
Right now, I'm attempting to group multiple records into a single structure for improved organization of data. Essentially letting us only need to import this PV structure rather than importing several records manually. As for what client(s) will consume this data structure. That would primarily be other IOCs themselves that are on the same subnet, but in different machines.
Sincerely,
Dhruv Srinivas
-----Original Message-----
Sent: Saturday, July 8, 2023 6:05 PM
To: Srinivas, Dhruv <[email protected]>
Cc: [email protected]
Subject: Re: Question on Accessing Data in Custom PV Structures
On 7/7/23 14:03, Srinivas, Dhruv via Tech-talk wrote:
> To whom it may concern,
> I’m attempting to create custom PVStructures which contain differing normative types. At the moment, I’ve created the below code in an IOC which creates a PV Structure with 2 NTScalars and 1 NTScalarArray.
Can you say something about what you are trying to accomplish, and what kind of client(s) will consume this data structure?
> record(ai, "rec:X") {
>                 field(VAL, "20")
>                 field(HIGH, "30")
>                 field(HSV, "MINOR")
>                 info(Q:group, {
>                                "CustomDataStructure": {
>                                               "X_Scalar": {
>                                                              +channel:"VAL"
> record(ai, "rec:Y") {
>                 field(VAL, "40")
>                 info(Q:group, {
>                                               "Y_Scalar": {
> +type:"scalar",
> +channel:"VAL",
> +id:"MyTestingPVA2PVA",
> record(aai, "input_this") {
>                 field(NELM, "4")
>                 field(FTVL, "INT64")
>                 field(INP, "[1,2,3,4]")
>                 info(Q:group, {
>                                               "Z_Aray": {
>                                                              +channel:"VAL"
> At the moment, this does create the PV Structure, and I can access it through “pvget”. However I’m unsure if this is the right way to do this. Can someone with more experience with Epics v7 correct me if so? Also, I’m not sure how to go about accessing parts of “CustomDataStructure”. Namely how would I go about accessing the value for Y_Scalar through CustomDataStructure?
> I’ve also copied the output of pvget below. I apologize for the lengthy post, but I thought it was best to provide as much context as possible.
>   * pvget CustomDataStructure
> CustomDataStructure MyTestingPVA2PVA
>      structure record
>          structure _options
>              uint queueSize 0
>              boolean atomic true
>      epics:nt/NTScalar:1.0 X_Scalar
>          double value 20
>          alarm_t alarm
>              int severity 0
>              int status 2
>              string message UDF
>          structure timeStamp
>              long secondsPastEpoch 631152000
>              int nanoseconds 0
>              int userTag 0
>          structure display
>              double limitLow 0
>              double limitHigh 0
>              string description
>              string units
>              int precision 0
>              enum_t form (0) Default
>                  int index 0
>                  string[] choices [Default, String, Binary, Decimal,
> Hex, Exponential, Engineering]
>          control_t control
>              double limitLow 0
>              double limitHigh 0
>              double minStep 0
>          valueAlarm_t valueAlarm
>              boolean active false
>              double lowAlarmLimit nan
>              double lowWarningLimit nan
>              double highWarningLimit 30
>              double highAlarmLimit nan
>              int lowAlarmSeverity 0
>              int lowWarningSeverity 0
>              int highWarningSeverity 0
>              int highAlarmSeverity 0
>              byte hysteresis 0
>      epics:nt/NTScalar:1.0 Y_Scalar
>          double value 40
>          alarm_t alarm
>              int severity 0
>              int status 2
>              string message UDF
>          structure timeStamp
>              int nanoseconds 0
>              int userTag 0
>          structure display
>              double limitLow 0
>              double limitHigh 0
>              string description
>              string units
>              int precision 0
>                  int index 0
>          control_t control
>              double limitLow 0
>              double limitHigh 0
>              double minStep 0
>              double highWarningLimit nan
>              byte hysteresis 0
>      epics:nt/NTScalarArray:1.0 Z_Scalar
>          long[] value [1,2,3,4]
>          alarm_t alarm INVALID DRIVER UDF
>              int severity 3
>              int status 2
>              string message UDF
>          structure timeStamp
>              int nanoseconds 0
>              int userTag 0
>          structure display
>              double limitLow 0
>              double limitHigh 0
>              string description
>              string units
>              int precision 0
>                  int index 0
>          control_t control
>              double limitLow 0
>              double limitHigh 0
>              double minStep 0
>              byte hysteresis 0
> Sincerely,
> Dhruv Srinivas
> [email protected] <mailto:[email protected]>
Re: Question on Accessing Data in Custom PV Structures Michael Davidsaver via Tech-talk
Question on Accessing Data in Custom PV Structures Srinivas, Dhruv via Tech-talk
Prev: RE: [EXTERNAL] Re: Real-Time Spectral Analysis of streaming data in EPICS operator screens. Evans, Richard K. (GRC-H000) via Tech-talk
Next: Re: Question on Accessing Data in Custom PV Structures Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Question on Accessing Data in Custom PV Structures Michael Davidsaver via Tech-talk
