On 7/10/23 08:18, Srinivas, Dhruv wrote:
Right now, I'm attempting to group multiple records into a single structure for improved organization of data. Essentially letting us only need to import this PV structure rather than importing several records manually.
The motivating use case for the PVA group feature is data atomicity. In the
context of your example if "rec:X" and "rec:Y" really are two parts of a tuple,
and must be consumed together, then a group make sense to avoid the possibility
of off-by-one errors of X wrt. Y which are probable when subscribing to each
individually.
On the other hand, if "X" and "Y" are only loosely related. Just happening to
be in in the same IOC. Then I am unsure including them in the same PVA group
will be of any benefit. It may even be a drawback as it means coming up with
names for the fields of the group. As we all know, naming is the hardest
problem in controls!
As for what client(s) will consume this data structure. That would primarily be other IOCs themselves that are on the same subnet, but in different machines.
In that case, I would suggest looking at
https://epics-base.github.io/pva2pva/qsrv_page.html#qsrv_link
In particular the "field" key, which can index into an arbtrary
PVD structure. For the example below, something like
record(ai, "client:X") {
field(INP, {pva:{
pv:"CustomDataStructure",
field:"X_Scalar",
proc:"CP"
Sincerely,
Dhruv Srinivas
-----Original Message-----
Sent: Saturday, July 8, 2023 6:05 PM
To: Srinivas, Dhruv <[email protected]>
Cc: [email protected]
Subject: Re: Question on Accessing Data in Custom PV Structures
On 7/7/23 14:03, Srinivas, Dhruv via Tech-talk wrote:
To whom it may concern,
I’m attempting to create custom PVStructures which contain differing normative types. At the moment, I’ve created the below code in an IOC which creates a PV Structure with 2 NTScalars and 1 NTScalarArray.
Can you say something about what you are trying to accomplish, and what kind of client(s) will consume this data structure?
record(ai, "rec:X") {
field(VAL, "20")
field(HIGH, "30")
field(HSV, "MINOR")
info(Q:group, {
"CustomDataStructure": {
"X_Scalar": {
+channel:"VAL"
record(ai, "rec:Y") {
field(VAL, "40")
info(Q:group, {
"Y_Scalar": {
+type:"scalar",
+channel:"VAL",
+id:"MyTestingPVA2PVA",
record(aai, "input_this") {
field(NELM, "4")
field(FTVL, "INT64")
field(INP, "[1,2,3,4]")
info(Q:group, {
"Z_Aray": {
+channel:"VAL"
At the moment, this does create the PV Structure, and I can access it through “pvget”. However I’m unsure if this is the right way to do this. Can someone with more experience with Epics v7 correct me if so? Also, I’m not sure how to go about accessing parts of “CustomDataStructure”. Namely how would I go about accessing the value for Y_Scalar through CustomDataStructure?
I’ve also copied the output of pvget below. I apologize for the lengthy post, but I thought it was best to provide as much context as possible.
* pvget CustomDataStructure
CustomDataStructure MyTestingPVA2PVA
structure record
structure _options
uint queueSize 0
boolean atomic true
epics:nt/NTScalar:1.0 X_Scalar
double value 20
alarm_t alarm
int severity 0
int status 2
string message UDF
structure timeStamp
long secondsPastEpoch 631152000
int nanoseconds 0
int userTag 0
structure display
double limitLow 0
double limitHigh 0
string description
string units
int precision 0
enum_t form (0) Default
int index 0
string[] choices [Default, String, Binary, Decimal,
Hex, Exponential, Engineering]
control_t control
double limitLow 0
double limitHigh 0
double minStep 0
valueAlarm_t valueAlarm
boolean active false
double lowAlarmLimit nan
double lowWarningLimit nan
double highWarningLimit 30
double highAlarmLimit nan
int lowAlarmSeverity 0
int lowWarningSeverity 0
int highWarningSeverity 0
int highAlarmSeverity 0
byte hysteresis 0
epics:nt/NTScalar:1.0 Y_Scalar
double value 40
alarm_t alarm
int severity 0
int status 2
string message UDF
structure timeStamp
int nanoseconds 0
int userTag 0
structure display
double limitLow 0
double limitHigh 0
string description
string units
int precision 0
int index 0
control_t control
double limitLow 0
double limitHigh 0
double minStep 0
double highWarningLimit nan
byte hysteresis 0
epics:nt/NTScalarArray:1.0 Z_Scalar
long[] value [1,2,3,4]
alarm_t alarm INVALID DRIVER UDF
int severity 3
int status 2
string message UDF
structure timeStamp
int nanoseconds 0
int userTag 0
structure display
double limitLow 0
double limitHigh 0
string description
string units
int precision 0
int index 0
control_t control
double limitLow 0
double limitHigh 0
double minStep 0
byte hysteresis 0
Sincerely,
Dhruv Srinivas
[email protected] <mailto:[email protected]>
- RE: Question on Accessing Data in Custom PV Structures Srinivas, Dhruv via Tech-talk
- Re: Question on Accessing Data in Custom PV Structures Timo Korhonen via Tech-talk
- Question on Accessing Data in Custom PV Structures Srinivas, Dhruv via Tech-talk
- Re: Question on Accessing Data in Custom PV Structures Michael Davidsaver via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
