1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Re: PHAS and PINI
From: Timo Korhonen via Tech-talk <tech-talk at aps.anl.gov>
To: "Johnson, Andrew N." <anj at anl.gov>, Michael Davidsaver <mdavidsaver at gmail.com>, "Rivers, Mark L." <rivers at cars.uchicago.edu>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 19 Jul 2023 11:13:52 +0000
We can certainly take this issue up in the Documentathon; it will be a good task to get familiar with the documentation structure and workflow.
I am still working on the task list; I will add this item there unless somebody wants to do the editing in the meantime.
Timo
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of "Johnson, Andrew N. via Tech-talk" <tech-talk at aps.anl.gov>
Reply to: "Johnson, Andrew N." <anj at anl.gov>
Date: Tuesday, 18 July 2023 at 18:46
To: Michael Davidsaver <mdavidsaver at gmail.com>, "Rivers, Mark L." <rivers at cars.uchicago.edu>
On 7/18/23 11:29 AM, Michael Davidsaver via Tech-talk wrote:
On 7/18/23 08:57, Mark Rivers via Tech-talk wrote:
Folks,
Does PHAS control the order in which records with PINI=YES are processing during iocInit, even is SCAN=Passive?
Yes.
https://github.com/epics-base/epics-base/blob/42604fc794b6f26b60db953a230b52c1118d3039/modules/database/src/ioc/misc/iocInit.c#L593-L594
The Release Notes for R3.14.11 (when that was added) said:
PINI Processing and PHAS values
The PINI field now has its own menu type with four more choices, RUNRUNNINGPAUSE and PAUSED. The earlier NO and YES values for this field remain as before and cause the same processing as before. The new values cause records to be processed during the announcement of the new initHookAtIocRuninitHookAfterIocRunninginitHookAtIocPause and initHookAfterIocPaused states respectively.
Records with PINI=YES will be processed during the iocBuild stage of iocInit, follwed by records with PINI=RUN during the iocRun stage and records with PINI=RUNNING during the initHookAfterIocRunning stage. If an iocPause command is given, any records with PINI=PAUSE will be processed at the initHookAtIocPause stage followed by records with PINI=PAUSED will be processed at the initHookAfterIocPaused stage. A subsequent iocRun command causes the PINI=RUN and PINI=RUNNING records to be processed again.
The PHAS field now controls the order in which records are processed as a result of the PINI mechanism; within each stage, lower values of PHAS are scanned before higher ones.
I agree that the dbCommonRecord.html wording could be fixed (in dbCommon.dbd.pod), that page doesn't mention the choices for PINI other than YES either but if you follow the link in the table below to the menuPini.html file that describes them, and there it also mentions that PHAS is honored during PINI processing.
@Timo — a task for the Documentathon?
- Andrew
Complexity is free, it's Simplicity that takes work.
PHAS and PINI Mark Rivers via Tech-talk
Re: PHAS and PINI Michael Davidsaver via Tech-talk
Re: PHAS and PINI Johnson, Andrew N. via Tech-talk
Prev: RE: IOC using Sequencer Module Attempting to use libCom.so.3.18.1 Srinivas, Dhruv via Tech-talk
Next: Help generating envPaths Marco A. Barra Montevechi Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: Re: PHAS and PINI Johnson, Andrew N. via Tech-talk
Next: IOC using Sequencer Module Attempting to use libCom.so.3.18.1 Srinivas, Dhruv via Tech-talk
ANJ, 19 Jul 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
