Hello All,
My name is Merrill Jenkins and I am working on the Fermilab Mu2e Experiment.
I have been working on adapting CSS Phoebus to monitor and control the
Cosmic Ray Veto (CRV) for this experiment. Currently, there are no
electronics or software installed for the CRV at the experiment, so I
have put together a simulated system that uses an EPICS solftIoc. I
have been able to set up Phoebus to display read-back values for the
elements of the CRV detector. I have been able to setup the
alarm-server for these elements. (I have installed zookeeper, kafka and
I have been able to configure the alarms with alarm-server.sh.) The
alarm tree is populated, the alarm area panel works, the annunciation
panel works and so does the alarm table.
Phoebus will run for a while and then hang, especially if I change the
value of an element so that it trips an alarm. It seems that Phoebus
will hang if there are problems with the alarms package. I think, that
in this case, the program stops working because the alarm package wants
to log this change. (But, I could be wrong.) So I am trying to setup
the alarm-logger. However, I am not making any headway with setting up
the alarm-logger. Over the past year I have looked over posted
documentation and was able to solve many problems However, I don't see
any hints in the documentation on how to setup the alarm-logger after
installing elasticserver. Could someone point me to how to set up the
alarm-logger? (Also, if this is not the problem, could someone point me
to what this problem might be and how to solve it?)
A second issue, is how to include the electronics logbook (we are using
ECLAPI) into Phoebus for possible direct entries from Phoebus. I see
that there are several packages including "elog" and "olog". Is there
an easy way to adapt a new electronic logbook so that it may be accessed
by Phoebus?
Many thanks in advance for any help.
Merrill Jenkins
Merrill Jenkins
Professor of Physics
==== Mailing Address ====
Physics
411 University Blvd. N.
MSPB RM 115
Mobile, AL 36688
phone 251.414.8013
Dept: 251.460.6224
Fax: 251.460.6800
- Re: Need help with Phoebus Alarm E-logger and Interface to the E-mail Giovanni Savarese LNL via Tech-talk
- Re: [EXTERNAL] Need help with Phoebus Alarm E-logger and Interface to the E-mail Kasemir, Kay via Tech-talk
NTEnum Gabriel Fedel via Tech-talk
<2023>
2025
Re: NTEnum Gabriel Fedel via Tech-talk
<2023>
2025
ANJ, 24 Jul 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
