1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Re: [EXTERNAL] Need help with Phoebus Alarm E-logger and Interface to the E-mail
From: "Kasemir, Kay via Tech-talk" <tech-talk at aps.anl.gov>
To: Charles Jenkins <mjenkins at southalabama.edu>, Phoebus Tech Talk <tech-talk at aps.anl.gov>
Date: Fri, 21 Jul 2023 14:41:29 +0000
> The alarm tree is populated, the alarm area panel works, the annunciation
panel works and so does the alarm table.
So far so good…
> Phoebus will run for a while and then hang, especially if I change the
value of an element so that it trips an alarm.  It seems that Phoebus
will hang if there are problems with the alarms package.  I think, that
in this case, the program stops working because the alarm package wants
to log this change.  (But, I could be wrong.) So I am trying to setup
the alarm-logger.
You certainly don’t need the alarm logger. If you have problems running without the alarm logger, you’ll have the same problems plus new ones after you add the alarm logger.
First figure out what exactly hangs.
Does the alarm server still run, can you “ls” alarms on its console?
Does the alarm server still send status updates, as you can see via `monitor_topics.sh`?
Does something in the GUI hang? Start the GUI with only a display, only the alarm tree, only the alarm table, only the alarm annunciator. Which one is hanging?
Need help with Phoebus Alarm E-logger and Interface to the E-mail Charles Jenkins via Tech-talk
Prev: Re: Need help with Phoebus Alarm E-logger and Interface to the E-mail Giovanni Savarese LNL via Tech-talk
Next: Re: NTEnum Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Next: SNCSEQ Downloading Владимир Сергейчик via Tech-talk
ANJ, 24 Jul 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
