1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: [EXTERNAL] Re: Best Site to Download Latest Version of Phoebus
From: Charles Merrill Jenkins via Tech-talk <[email protected]>
To: Tynan Ford <[email protected]>, "Kasemir, Kay" <[email protected]>
Cc: Phoebus Tech Talk <[email protected]>
Date: Thu, 27 Jul 2023 11:55:13 -0500
Hello All,
The build fails even with skipping the tests.
I have just tried to build an older version of Phoebus, that did build in the past using jdk18 and maven.3.9.2.  And it failed with:
mvn clean install
I tried again with:
mvn -DskipTests clean install
And the build was successful. The problem is that I don't know what version of phoebus I used, and I have not tried to run it with the alarms server.  I will try to build the latest version of phoebus with jdk18 and maven.3.9.2 using the -DskipTests flag.
Merrill Jenkins
On 7/27/23 11:07, Tynan Ford wrote:
The unit test failure could be due to firewall rules blocking ports used in core-pva tests - https://github.com/ControlSystemStudio/phoebus/issues/2563
On Thu, Jul 27, 2023, 11:49 AM Kasemir, Kay via Tech-talk <[email protected]> wrote:
Hi:
> The build fails when using
> mvn clean install
> … [ERROR]   ServerClientTest.testSinglePV:259
>…[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
So it fails a unit test. That’s somewhat interesting, in principle the tests should pass, and they do for the automatic build on github. The issue could be related to bad luck for tests that depend on timing, or maybe it’s related to localization, some text looks different.
> I will try to use the -DskipTests for the clean install
Right, first build without the tests. Once that succeeds, you can try to debug the test failure, but that would be a second, optional step.
>  I am using jkd 20.0.2 and maven 3.9.3.
The JDK version could be a factor in the test result, but to know more we’d have to get the complete stack trace of the test failure.
Merrill Jenkins
Professor of Physics
==== Mailing Address ====
Physics
411 University Blvd. N.
MSPB RM 115
Mobile, AL 36688
phone 251.414.8013
Dept: 251.460.6224
Re: [EXTERNAL] Re: Best Site to Download Latest Version of Phoebus Charles Merrill Jenkins via Tech-talk
Best Site to Download Latest Version of Phoebus Charles Jenkins via Tech-talk
Re: [EXTERNAL] Re: Best Site to Download Latest Version of Phoebus Kasemir, Kay via Tech-talk
Re: [EXTERNAL] Re: Best Site to Download Latest Version of Phoebus Tynan Ford via Tech-talk
Prev: Re: [EXTERNAL] Re: Best Site to Download Latest Version of Phoebus Tynan Ford via Tech-talk
Next: Re: [EXTERNAL] Re: Best Site to Download Latest Version of Phoebus Charles Merrill Jenkins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
