1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: [EXTERNAL] Re: Best Site to Download Latest Version of Phoebus
From: Charles Merrill Jenkins via Tech-talk <[email protected]>
To: Tynan Ford <[email protected]>, "Kasemir, Kay" <[email protected]>
Cc: Phoebus Tech Talk <[email protected]>
Date: Thu, 27 Jul 2023 12:28:59 -0500
Hello All,
I have been able to get the current version of phoebus to build ( at least it says BUILD SUCCESS near the end).
I had to use jdk18 and maven.3.9.2 and skip the testing:
> git clone --recursive https://github.com/ControlSystemStudio/phoebus.git
> mvn clean verify -f dependencies/pom.xml
> mvn -DskipTests clean install
I have not tried to run this build with the alarms system yet.  I need to setup EPICS and kafka.  Because of the problems I have had, I think I will not use the current kafka version, but  kafka_2.31-3.5.0.
Merrill Jenkins
On 7/27/23 11:55, Charles Merrill Jenkins wrote:
Hello All,
The build fails even with skipping the tests.
I have just tried to build an older version of Phoebus, that did build in the past using jdk18 and maven.3.9.2.  And it failed with:
mvn clean install
I tried again with:
And the build was successful. The problem is that I don't know what version of phoebus I used, and I have not tried to run it with the alarms server.  I will try to build the latest version of phoebus with jdk18 and maven.3.9.2 using the -DskipTests flag.
Merrill Jenkins
On 7/27/23 11:07, Tynan Ford wrote:
The unit test failure could be due to firewall rules blocking ports used in core-pva tests - https://github.com/ControlSystemStudio/phoebus/issues/2563
On Thu, Jul 27, 2023, 11:49 AM Kasemir, Kay via Tech-talk <[email protected]> wrote:
Hi:
> The build fails when using
> mvn clean install
> … [ERROR]   ServerClientTest.testSinglePV:259
>…[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
So it fails a unit test. That’s somewhat interesting, in principle the tests should pass, and they do for the automatic build on github. The issue could be related to bad luck for tests that depend on timing, or maybe it’s related to localization, some text looks different.
> I will try to use the -DskipTests for the clean install
Right, first build without the tests. Once that succeeds, you can try to debug the test failure, but that would be a second, optional step.
>  I am using jkd 20.0.2 and maven 3.9.3.
The JDK version could be a factor in the test result, but to know more we’d have to get the complete stack trace of the test failure.
Merrill Jenkins
Professor of Physics
==== Mailing Address ====
Physics
411 University Blvd. N.
MSPB RM 115
Mobile, AL 36688
phone 251.414.8013
Dept: 251.460.6224
Merrill Jenkins
Physics
MSPB RM 115
Mobile, AL 36688
phone 251.414.8013
Dept: 251.460.6224
Best Site to Download Latest Version of Phoebus Charles Jenkins via Tech-talk
Re: Best Site to Download Latest Version of Phoebus Charles Merrill Jenkins via Tech-talk
Re: [EXTERNAL] Re: Best Site to Download Latest Version of Phoebus Kasemir, Kay via Tech-talk
Re: [EXTERNAL] Re: Best Site to Download Latest Version of Phoebus Charles Merrill Jenkins via Tech-talk
Re: [EXTERNAL] Re: Best Site to Download Latest Version of Phoebus Tynan Ford via Tech-talk
Prev: Re: [EXTERNAL] Re: Best Site to Download Latest Version of Phoebus Charles Merrill Jenkins via Tech-talk
Next: Process aSub record on arrival of data Matt Rippa via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: Re: [EXTERNAL] Re: Best Site to Download Latest Version of Phoebus Charles Merrill Jenkins via Tech-talk
