1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: xspress3 Realtime not arrived when set 100s
From: lynn via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk <tech-talk at aps.anl.gov>
Date: Thu, 3 Aug 2023 10:33:10 +0800 (CST)
Dear experts,
    Xspress3 Realtime was 46.31s when set 100s. It was normal when the acquire time less.
    P.S. It is xspress3 1Chan.
    When use IOC from Github: (macro was: XSP_1Chan)
    The realtime was always 46.31, when acquire time set to 100 seconds. We tried several times, the result was same.
    And "XSPS_1Chan:C1SCA:0:Value_RBV" was 3.70503e+09. ( 3.70503e+09 / 8000000 = 46.31)
   Then we changed IOC from verder:( macro was XSPRESS3-EXAMPLE)
   The realtime was still 46s, i mean the xspress stop acquire at 46s when set 100s.
    And XSPRESS-EXAMPLE:C1_SCA0:Value_RBV was  -5.89935e+08.
    If you did not have a device, we would like to support.
    teamview or other software was ok.
Lynn
Re: xspress3 Realtime not arrived when set 100s Matt Newville via Tech-talk
Prev: Requesting SDD Detector driver for Skyray spectrometer Manny Mathuthu via Tech-talk
Next: Epics7 Liridon Deda via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Next: Re: xspress3 Realtime not arrived when set 100s Matt Newville via Tech-talk
ANJ, 03 Aug 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
