1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Epics7
From: Liridon Deda via Tech-talk <tech-talk at aps.anl.gov>
To: <Tech-talk at aps.anl.gov>
Date: Thu, 3 Aug 2023 11:06:56 +0200
I have a working Epics7 installation on a Windows machine with Anaconda installed and tried to build pyDevSup as module, but didn't succeed so far. I also tried it on an Ubuntu machine, and there it works fine. First, I had some issues that numpy from the Anaconda installation was not found, but this is solved. No, I get the following output:
(base) C:\opt\epics\modules\pyDevSup>gmake
gmake -C ./configure install
gmake[1]: Entering directory 'C:/opt/epics/modules/pyDevSup/configure'
perl -CSD C:/opt/epics/base/bin/windows-x64-static/makeMakefile.pl O.windows-x64-static ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
gmake -C O.windows-x64-static -f ../Makefile TOP=../.. \
    T_A=windows-x64-static install
gmake[2]: Entering directory 'C:/opt/epics/modules/pyDevSup/configure/O.windows-x64-static'
perl -CSD C:/opt/epics/base/bin/windows-x64-static/convertRelease.pl checkRelease
C:\ProgramData\Anaconda3\python.exe ../../makehelper.py os/CONFIG_PY.Common.windows-x64-static
"Installing config file ../../configure/os/CONFIG_PY.Common.windows-x64-static"
gmake[2]: Leaving directory 'C:/opt/epics/modules/pyDevSup/configure/O.windows-x64-static'
gmake[1]: Leaving directory 'C:/opt/epics/modules/pyDevSup/configure'
gmake -C ./archApp install
gmake[1]: Entering directory 'C:/opt/epics/modules/pyDevSup/archApp'
gmake[2]: Entering directory 'C:/opt/epics/modules/pyDevSup/archApp/O.windows-x64-static'
'[' is not recognized as an internal or external command,
operable program or batch file.
'install' is not recognized as an internal or external command,
gmake[2]: *** [../../configure/RULES_PY:10: ../../python39/windows-x64-static/bplreport.py] Error 1
gmake[2]: Leaving directory 'C:/opt/epics/modules/pyDevSup/archApp/O.windows-x64-static'
gmake[1]: *** [/opt/epics/base/configure/RULES_ARCHS:58: install.windows-x64-static] Error 2
gmake[1]: Leaving directory 'C:/opt/epics/modules/pyDevSup/archApp'
gmake: *** [/opt/epics/base/configure/RULES_DIRS:85: archApp.install] Error 2
Does anyone have an Idea what could be the problem and how can I fix it.
Thanks a lot
Liridon
Re: Epics7 Ralph Lange via Tech-talk
Re: Epics7 (pyDevSup) Michael Davidsaver via Tech-talk
Prev: xspress3 Realtime not arrived when set 100s lynn via Tech-talk
Next: Re: Epics7 Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: Re: xspress3 Realtime not arrived when set 100s Matt Newville via Tech-talk
ANJ, 03 Aug 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
