1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: archiver appliance - PVs not reconnecting
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Thu, 3 Aug 2023 18:25:30 +0200
On Thu, 3 Aug 2023 at 17:40, Pierrick M Hanlet via Tech-talk <[email protected]> wrote:
This problem is similar to
https://epics.anl.gov/tech-talk/2020/msg01951.php, but not the same.
I have an archiver appliance which has been happily running on a Alma
Linux server for several months. We had a
maintenance shutdown  which turned off the IOC servers, but the archiver
remained active.  When the system
came back up again, ~150 PVs, which I verified as alive and active,
would not reconnect, whereas thousands more
did reconnect as usual.  Any ideas?
What you could try:
Start an IOC (loading a single record with an arbitrary nonexisting name is enough) in the network that the archiver is in or listens to. (Depends on the exact configuration of your engine.)
That will create a Channel Access beacon signal "new IOC coming up" that any client library may see as a hint to try reconnecting disconnected channels. Note that the caRepeater is needed to be running on the client (archiver) machine for this to work.
Start/stop that extra IOC a few times. (Even if it doesn't help, it will hardly have any side effects.)
Cheers,
~Ralph
archiver appliance - PVs not reconnecting Pierrick M Hanlet via Tech-talk
Prev: archiver appliance - PVs not reconnecting Pierrick M Hanlet via Tech-talk
Next: Re: How to reset encoder counts after controller power off Kevin Peterson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Next: Re: archiver appliance - PVs not reconnecting Hu, Yong via Tech-talk
