1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: archiver appliance - PVs not reconnecting
To: Pierrick M Hanlet <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 3 Aug 2023 18:41:17 +0000
Hello Pierrick,
We had this kind of issues at NSLS-2. I usually go to the log files (archiver-installation-directory/engine/logs) to troubleshoot those PVs (grep pvName *). In our cases, most issues are actually related to the IOCs after rebooting: the timestamps of not-auto-reconnected PVs are totally wrong; the record types are changed; the PVs are updating faster; etc.
You do not need to remove those PVs to re-archive them. I usually pause then resume them. If you do want to remove those PVs being archived from the web interface, I think there is a pop-up window warning if you want to delete the data as well. It is a common sense that the historical archived data should be kept unless users specifically delete them.
HTH,
Yong
From: Tech-talk <[email protected]> on behalf of Pierrick M Hanlet via Tech-talk <[email protected]>
Date: Thursday, August 3, 2023 at 11:40 AM
To: [email protected] <[email protected]>
Subject: archiver appliance - PVs not reconnecting
This problem is similar to
https://epics.anl.gov/tech-talk/2020/msg01951.php, but not the same.
I have an archiver appliance which has been happily running on a Alma
Linux server for several months. We had a
maintenance shutdown  which turned off the IOC servers, but the archiver
remained active.  When the system
came back up again, ~150 PVs, which I verified as alive and active,
would not reconnect, whereas thousands more
did reconnect as usual.  Any ideas?
Question: If I remove these PVs from the archiver and then add them back
in, will we lose historical data?
Many thanks,
Pierrick
Pierrick Hanlet
Fermi National Accelerator
Accelerator Front End Controls
+1-630-840-5555 -- lab
+1-312-687-4980 -- mobile
"Whether you think you can or think you can't, you're right" -- Henry Ford
archiver appliance - PVs not reconnecting Pierrick M Hanlet via Tech-talk
Prev: Re: How to reset encoder counts after controller power off Kevin Peterson via Tech-talk
Next: Re: Epics7 (pyDevSup) Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: archiver appliance - PVs not reconnecting Ralph Lange via Tech-talk
Next: problem reading data from PLC Abhishek Dutta via Tech-talk
