1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: netDev "channels" record type problem
From: "Arnold, Ned D. via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, Владимир Сергейчик <[email protected]>
Date: Mon, 7 Aug 2023 11:55:49 +0000
In your attached database, the first record is a custom record named "channels".  My guess is that this custom record is not invoking the FLNK properly in its code.
   Ned
record(channels,"IR:something:GM10:channels"){
   field(SCAN,"1 second")
   field(DTYP,"Darwin")
   field(INP,"@192.168.11.101(34151)#001,002")
   field(NELM,"2")
   field(FLNK,"IR:something:T1.PROC CA")
record(ao,"IR:something:T1"){
   field(SCAN,"Passive")
   field(OMSL,"closed_loop")
   field(EGU,"degree")
   field(DOL,"IR:something:GM10:channels.CH01")
   field(DESC, "something temp before HEX")
   field(FLNK,"IR:something:T2.PROC CA")
From: Tech-talk <[email protected]> on behalf of Владимир Сергейчик via Tech-talk <[email protected]>
Sent: Monday, August 7, 2023 04:10 AM
To: [email protected] <[email protected]>
Subject: netDev "channels" record type problem
Hello everyone! I want to read out data from GM10 data logger, using netDev "channels" record type (it turns the set of PVs into an array). However, I have encountered some problem: I need to use "Passive" SCAN mode for the elements of that array, however, it would work only if I add .PROC CA to the FLNK line:
field(FLNK,"IR:something:T1.") -> field(FLNK,"IR:something:T1.PROC CA")
Only in this case it starts working properly. (By "working properly" I mean that while processing the data from datalogger both individual PV and the corresponding element of the array change simultaneously, while in other case the element of array changes whereas the value of a particular PV remains unchanged). Meanwhile, while looking at scripts of other users, they do not use .PROC CA addition and everything works OK.
Could you explain why the field(FLNK,"IR:something:T1.") (without .PROC CA) doesn't work and how it can be fixed (because simple adding of .PROC CA doesn't seem to be a correct solution, otherwise other users would also add it).
For better understanding of the context, I attach the example db-file. The first record is "channels" record type (which is array), and two others are scalar PV.
Vladimir
netDev "channels" record type problem Владимир Сергейчик via Tech-talk
Prev: Re: problem reading data from PLC Sebastian Marsching via Tech-talk
Next: Re: netDev "channels" record type problem Shuei YAMADA via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: netDev "channels" record type problem Владимир Сергейчик via Tech-talk
