Sir, I've been trying to establish communication with S7 1500 PLC. Trying to read IW0, MD0. While starting the IOC, I don't get any syntax error etc. The message shows following: #!../../bin/linux-x86_64/myS7 < envPaths epicsEnvSet("IOC","iocmyS7") epicsEnvSet("TOP","/ics/tools/myS7") epicsEnvSet("ASYN","/ics/tools/asyn4-38") epicsEnvSet("S7NODAVE","/home/training/Desktop/ics/tools/s7nodave-3.0.2") epicsEnvSet("EPICS_BASE","/ics/tools/base-7.0.6") epicsEnvSet("ETHER_IP","/ics/tools/ether_ip") epicsEnvSet("SNCSEQ","/ics/tools/seq-2.2.9") epicsEnvSet("AUTOSAVE","/ics/tools/autosave-R5-10-2") epicsEnvSet("STREAM","/ics/tools/StreamDevice-master") epicsEnvSet("BUSY","/ics/tools/busy-1-6-1") epicsEnvSet("PVXS","/ics/tools/pvxs") epicsEnvSet("PYDEVICE","/ics/tools/PyDevice-R1.1.1") cd "/ics/tools/myS7" ## Register all support components dbLoadDatabase "dbd/myS7.dbd" myS7_registerRecordDeviceDriver pdbbase #var mySubDebug 1 #traceIocInit cd "/ics/tools/myS7/iocBoot/iocmyS7" ## Load record instances #dbLoadTemplate "user.substitutions" #dbLoadRecords "user.db" < hall.cmd s7nodaveConfigureIsoTcpPort("HallPLC","192.168.0.1",0,1,0) s7nodaveConfigurePollGroup("HallPLC",'default',1.0,0) s7nodaveConfigurePollGroup("HallPLC",'fast',0.1,0) dbLoadRecords "hall1.db" iocInit Starting iocInit ############################################################################ ## EPICS R7.0.6 ## Rev. 2021-09-28T15:27-0400 ############################################################################ iocRun: All initialization complete ## Start any sequence programs #seq sncExample, "user=training" epics> 2023/08/01 21:01:20.281 HallPLC error while reading 2 bytes from PLC address IB0. 2023/08/01 21:01:20.283 HallPLC error while reading 4 bytes from PLC address FB0. IOC name is myS7 and following is the hall1.db file. It resides in the same st.cmd directory: record(ai, "hall_ip1") { field(SCAN,"1 second") field(DTYP,"s7nodave") field(INP, "@HallPLC(DLV=0,DHV=27648) IW0 int16") field(EGU,"V") } record(ai, "hall_uvolt") { field(SCAN,"1 second") field(DTYP,"s7nodave") field(INP, "@HallPLC MD0 float") field(EGU,"V") } Please suggest solution for the same. Regards, Abhishek Dutta
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
