1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: netDev "channels" record type problem
From: Shuei YAMADA via Tech-talk <[email protected]>
To: Владимир Сергейчик <[email protected]>
Cc: [email protected]
Date: Thu, 10 Aug 2023 22:28:22 +0900
Dear Vlad,
Your symptom and workaround sounds as if IR:something:GM10:channels
and IR:something:T1 are located in different IOCs.
Could you check if they are located in the same IOC?
If they are in different IOCs you may have to specify .PROC field in
the FLNK field , as described in the EPICS Application Developer’s
Guide, 5.12.3 FWDLINK :
https://epics.anl.gov/base/R3-15/6-docs/AppDevGuide/DatabaseLockingScanningAndProcessing.html#x6-2000005.12.3
best regards,
Shuei
                 Shuei Yamada,
                 High Energy Accelerator Research Organization (KEK)
                 mailto:[email protected]
netDev "channels" record type problem Владимир Сергейчик via Tech-talk
Re: netDev "channels" record type problem Shuei YAMADA via Tech-talk
Re: netDev "channels" record type problem Владимир Сергейчик via Tech-talk
Prev: Re: [EXTERNAL] Scripts in Phoebus Florian Feldbauer via Tech-talk
Next: Re: Using opencv with areaDetector William Smith via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: netDev "channels" record type problem Владимир Сергейчик via Tech-talk
Next: problem reading data from PLC S7NODAVE Abhishek Dutta via Tech-talk
