1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: netDev "channels" record type problem
From: Владимир Сергейчик via Tech-talk <[email protected]>
To: Shuei YAMADA <[email protected]>
Cc: [email protected]
Date: Tue, 8 Aug 2023 11:35:19 +0900
Hello Shuei,
I am using EPICS R7.0.7 and netDev-1.0.7
Пн, 7 авг. 2023 г. в 9:32 PM, Shuei YAMADA <[email protected]>:
Hi Vlad,
First of all I have two questions:
Which version of netDev and EPICS base are you using?
Why don't you use ai records for IR:something:T1 (or T2) instead of ao records?
regards,
Shuei
p.s.
Currently I'm on vacation and I don't have access to our working
version of netDev. I'll look into it when I get back
2023年8月7日(月) 18:34 Владимир Сергейчик via Tech-talk <[email protected]>:
> Hello everyone! I want to read out data from GM10 data logger, using netDev "channels" record type (it turns the set of PVs into an array). However, I have encountered some problem: I need to use "Passive" SCAN mode for the elements of that array, however, it would work only if I add .PROC CA to the FLNK line:
> field(FLNK,"IR:something:T1.") -> field(FLNK,"IR:something:T1.PROC CA")
> Only in this case it starts working properly. (By "working properly" I mean that while processing the data from datalogger both individual PV and the corresponding element of the array change simultaneously, while in other case the element of array changes whereas the value of a particular PV remains unchanged). Meanwhile, while looking at scripts of other users, they do not use .PROC CA addition and everything works OK.
> Could you explain why the field(FLNK,"IR:something:T1.") (without .PROC CA) doesn't work and how it can be fixed (because simple adding of .PROC CA doesn't seem to be a correct solution, otherwise other users would also add it).
> For better understanding of the context, I attach the example db-file. The first record is "channels" record type (which is array), and two others are scalar PV.
> Thanks,
> Vladimir
                 Shuei Yamada,
                 High Energy Accelerator Research Organization (KEK)
                 mailto:[email protected]
Re: netDev "channels" record type problem Shuei YAMADA via Tech-talk
netDev "channels" record type problem Владимир Сергейчик via Tech-talk
Prev: Re: problem reading data from PLC S7NODAVE Maren Purves via Tech-talk
Next: Using opencv with areaDetector William Smith via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: netDev "channels" record type problem Shuei YAMADA via Tech-talk
Next: Re: netDev "channels" record type problem Shuei YAMADA via Tech-talk
