1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Using opencv with areaDetector
From: William Smith via Tech-talk <[email protected]>
To: "Mark Rivers" <[email protected]>
Date: Thu, 10 Aug 2023 19:12:05 +0200
I found that I could get it to build only when I used CONFIG_SITE.local with the following:
# OPENCV is required for the ADPluginEdge plugin
WITH_OPENCV = YES
OPENCV_EXTERNAL = YES
OPENCV_INCLUDE = /usr/include/opencv4
#OPENCV_LIB =
If I used the following then ADPluginBar will build, but any IOC that uses it will fail to build with the error messages already described.
WITH_OPENCV = YES
OPENCV_LIB = /usr/lib
Hopefully this will help someone else in the future. It's a bit confusing because the include files have to be specified because of a change in the location that they are saved for opencv4. Specifying the OPENCV_LIB parameter breaks the build of the IOCs.
Will
--------------------Original message--------------------
Sent: Tuesday, August 8, 2023 15:16
Cc: [email protected]
Here is the output after running make clean uninstall; make in ADSimDetector.
make[5]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorIOC/simDetectorApp/Db/O.linux-x86_64'
make[4]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorIOC/simDetectorApp/Db'
make[5]: *** No rule to make target '../../../lib/linux-x86_64/libopencv_core.a', needed by 'simDetectorNoIOCApp'. Stop.
make[5]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp/src/O.linux-x86_64'
make[4]: *** [/opt/epics/epics-base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[4]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp/src'
make[3]: *** [/opt/epics/epics-base/configure/RULES_DIRS:85: src.install] Error 2
make[3]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp'
make[2]: *** [/opt/epics/epics-base/configure/RULES_DIRS:85: simDetectorNoIOCApp.install] Error 2
make[2]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorNoIOC'
make[1]: *** [/opt/epics/epics-base/configure/RULES_DIRS:85: simDetectorNoIOC.install] Error 2
make[1]: *** Waiting for unfinished jobs....
make[5]: *** No rule to make target '../../../lib/linux-x86_64/libopencv_core.a', needed by 'simDetectorApp'. Stop.
make[5]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorIOC/simDetectorApp/src/O.linux-x86_64'
make[4]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorIOC/simDetectorApp/src'
make[3]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorIOC/simDetectorApp'
make[2]: *** [/opt/epics/epics-base/configure/RULES_DIRS:85: simDetectorApp.install] Error 2
make[2]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorIOC'
make[1]: *** [/opt/epics/epics-base/configure/RULES_DIRS:85: simDetectorIOC.install] Error 2
make[1]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/iocs'
make: *** [/opt/epics/epics-base/configure/RULES_DIRS:85: iocs.install] Error 2
Sent: Tuesday, August 8, 2023 15:11
make -C /opt/epics/areaDetector/ADSimDetector install
make[1]: Entering directory '/opt/epics/areaDetector/ADSimDetector'
make -C ./configure install
make[2]: Entering directory '/opt/epics/areaDetector/ADSimDetector/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
T_A=linux-x86_64 install
make[3]: Entering directory '/opt/epics/areaDetector/ADSimDetector/configure/O.linux-x86_64'
perl -CSD /opt/epics/epics-base/bin/linux-x86_64/convertRelease.pl checkRelease
make[3]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/configure/O.linux-x86_64'
make[2]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/configure'
make -C ./simDetectorApp install
make[2]: Entering directory '/opt/epics/areaDetector/ADSimDetector/simDetectorApp'
make -C ./src install
make[3]: Entering directory '/opt/epics/areaDetector/ADSimDetector/simDetectorApp/src'
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[4]: Entering directory '/opt/epics/areaDetector/ADSimDetector/simDetectorApp/src/O.linux-x86_64'
make[4]: Nothing to be done for 'install'.
make[4]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/simDetectorApp/src/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/simDetectorApp/src'
make -C ./Db install
make[3]: Entering directory '/opt/epics/areaDetector/ADSimDetector/simDetectorApp/Db'
make[4]: Entering directory '/opt/epics/areaDetector/ADSimDetector/simDetectorApp/Db/O.linux-x86_64'
make[4]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/simDetectorApp/Db/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/simDetectorApp/Db'
make -C ./op install
make[3]: Entering directory '/opt/epics/areaDetector/ADSimDetector/simDetectorApp/op'
make[3]: Nothing to be done for 'install'.
make[3]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/simDetectorApp/op'
make[2]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/simDetectorApp'
make -C ./iocs install
make[2]: Entering directory '/opt/epics/areaDetector/ADSimDetector/iocs'
make -C ./simDetectorNoIOC install
make[3]: Entering directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorNoIOC'
make[4]: Entering directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorNoIOC/configure'
make[5]: Entering directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorNoIOC/configure/O.linux-x86_64'
make[5]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorNoIOC/configure/O.linux-x86_64'
make[4]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorNoIOC/configure'
make -C ./simDetectorNoIOCApp install
make[4]: Entering directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp'
make[5]: Entering directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp/src'
make[6]: Entering directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp/src/O.linux-x86_64'
make[6]: *** No rule to make target '../../../lib/linux-x86_64/libopencv_core.a', needed by 'simDetectorNoIOCApp'. Stop.
make[6]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp/src/O.linux-x86_64'
make[5]: *** [/opt/epics/epics-base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[5]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp/src'
make[4]: *** [/opt/epics/epics-base/configure/RULES_DIRS:85: src.install] Error 2
make[4]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp'
make[3]: *** [/opt/epics/epics-base/configure/RULES_DIRS:85: simDetectorNoIOCApp.install] Error 2
make[3]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/iocs/simDetectorNoIOC'
make[2]: *** [/opt/epics/epics-base/configure/RULES_DIRS:85: simDetectorNoIOC.install] Error 2
make[2]: Leaving directory '/opt/epics/areaDetector/ADSimDetector/iocs'
make[1]: *** [/opt/epics/epics-base/configure/RULES_DIRS:85: iocs.install] Error 2
make[1]: Leaving directory '/opt/epics/areaDetector/ADSimDetector'
make: *** [/opt/epics/epics-base/configure/RULES_DIRS:85: /opt/epics/areaDetector/ADSimDetector.install] Error 2
Sent: Tuesday, August 8, 2023 13:31
To: William Smith <[email protected]>
Send the complete link line that fails.
Sent from my iPhone
On Aug 8, 2023, at 5:17 AM, William Smith via Tech-talk <[email protected]> wrote:
Dear Tech-Talk,
I am trying to use opencv with areaDetector. To start, I have been trying to build with the ADPluginEdge plugin
I am using ubuntu 20.04
I have pulled AD 3-12-1
I have installed opencv using the package manager. sudo apt install libopencv-dev
I have checked that the commonDriverMakefile in ADCore contains ifdef ADPLUGINBAR....
I have checked that in CONFIG_SITE.local.linux-x86_64 the following is set
WITH_OPENCV = YES
I had to add the include directory because opencv 4.2.0 includes are under /usr/includes/opencv4
OPENCV = /usr
OPENCV_LIB = $(OPENCV)/lib
OPENCV_INCLUDE = -I$(OPENCV)/include/opencv4
ADSupport, ADCore and ADPluginEdge build without errors. Then when I try to build an example IOC using ADSimDetector I get the following error:
It feels like it isn't looking in the EXTERNAL location like I tell it to. Have I missed something? Does anyone have a suggestion?
Will
Prev: Re: netDev "channels" record type problem Shuei YAMADA via Tech-talk
Next: RE: MRF EvtClk object not found Daykin, Evan via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Using opencv with areaDetector William Smith via Tech-talk
Next: MRF EvtClk object not found Daykin, Evan via Tech-talk
